2016 rockshox pike ...
[Closed] 2016 rockshox pike solo air 140-160mm travel increase.
Hi all. Bought a new remedy with the 140mm pike on. I want to increase the travel up to 160mm. I understand I can get a new air shaft and I've watched a couple of vidal and read a few forum threads about it. But I'm still curious about the damper leg. Does anything need to be changed there and if not why not?? Any help greatly appreciated ta
Posted : 28/08/2016 8:44 pm
Nope just the air shaft.
Posted : 28/08/2016 8:48 pm
Thankyou
Posted : 28/08/2016 8:51 pm
Not to sure you can jump up 20mm
I changed my 150 to 160 but the markings on the air shaft were 150-26" 140-27.5" and 130-29"
I'm sure the new shaft went up by 10 mm on each size
Posted : 28/08/2016 9:39 pm
You can change it to any travel you like as long as you have the right shaft.
It has three sizes on it as the same air shaft is 160 in a 26" and 150 in a 650b as the part is the same for any size fork just makes it different travel.
Posted : 28/08/2016 10:01 pm
