Picked up what I thought were a good deal on forks per subject from CRC the other week, thinking I may use them on a Scott Scale for Mrs B.
It then occurred to me that they could be used on other bikes, if the travel could be upped to 120mm.
So...assuming these are OEM Reba's (generic box, no instructions, pump, etc) can the travel up upped by swapping out the airspring?
Thanks all.
Throw the serial number into this website and it should tell you what upgrades you can do (and what parts are required).
trailhead.rockshox.com/en/
Ive played about swapping bits between a set of 26 revelations and some 29er recons.
All seemed interchangeable. Ended up with 150mm 29er revcons and 26 re-
Lations
All worked well.
The fork lowers might dictate which damper you can use as the rebound knob on the recons is well recessed, whereas the revs are fully exposed.
