2015 Canyon Spectra...
[Closed] 2015 Canyon Spectral Bottom Bracket issue?
I have an issue with my BB on my 2015 Spectral AL 7.0ex
Sounds very much like the issue raised in this thread (Where no solution was posted)
singletrackworld.com/forum/topic/any-canyon-spectral-al-275-owners-here/
I have a spacer installed between the BB and crank (2.5mm) which is loose fitting and according to SRAM should not be there - t causes issues tightening the cranks but works if centrally aligned - without the cranks foul the frame.
Would appreciate some help, dontknow if it was this way from new but only picked up on it recently...
Thanks
Tom
Posted : 10/05/2018 5:37 pm
If its the same as the link you posted, I would put the spacer between the BB and the frame (on the non drive side) and refit your cranks. It should be fine.
Posted : 10/05/2018 6:01 pm
