What tyre size rang...
[Closed] What tyre size range on 35mm rims
[#9981141]
Hi - syncros x35 rims,
is there a way to find out the max / min tyre widths that I can use safely
Thanks
Posted : 10/05/2018 5:28 pm
Some tires work better than the others, but you can go from 2.3 to 3.0 on 35mm internal rim.
Posted : 10/05/2018 5:45 pm
Look up the ETRTO work, they have tables for max & min tyre widths for each width of rim. Actually the table I usually refer to does it the other way round: what rims are suitable for a tyre that is Xmm wide? It also only goes up to 29c rims.
A typical example: 19c rim will take tyres from 28mm to 62mm, roughly 1.5 times rim width to 3.2 times rim width.
Posted : 10/05/2018 5:53 pm
Take published sizes with a pinch of salt. A Maxxis 2.3 squares off on a Flow MK3 so you'd have no chance on a 35mm.
35mm internal is best used with tyres upwards of 2.6. Overkill otherwise.
Posted : 10/05/2018 5:54 pm
I assembled an 150/150 27.5+ bike recently. I'am not a fan of the 2.8 inch rubber (yet) - decided to go with 2.6 inch tyres.
After some reading and asking I picked 35 mm internal rims (FunWorks).
Those rims with the 2.6 inch Magic Mary: perfect match! Run the front tyre with a bit under 20 psi and rear a bit over 20 psi.
This bike is downhill a real beast. Absolutely happy with the rims/tyres.
2.8 inch rubber: rims around 40 mm ?
2.4 inch rubber: rims around 30 mm (or even 25 mm)?
Posted : 10/05/2018 6:15 pm
Thanks.
Presumably the 'x35 plus'  sticker means internal width of 35 (*they were a sod to get tubeless so I don't want to take the tyre off till it's knackered to measure), *so measuring with a tyre on - so not exact,measuring from outside edge to outside edge of the rim is about 40-41mm - does that make sense.
I did email syncros about the rim but they were unable to tell me the internal/external widths or what tyre sizes they supported (and yes I was somewhat unimpressed)
sounds like 2.6 is ok (OE fitting was 2.8)
Posted : 10/05/2018 6:37 pm
I'm running 2.35 Mary/Rock Razors on my internal 35mm/external 41mm Ibis wheels - they're spot on and come out similar size to a 2.5 Maxxis.
May try something bigger next but space is a bit limited on the current bike.
Posted : 11/05/2018 10:24 am
Maxxis has WT (wide trail?) tyre models starting at 2.4” width, I don’t know how much difference there is but I can say that 2.4” DHR2 WT is excellent on 35mm rims.
Posted : 11/05/2018 12:11 pm
