2012 XT - reset pad...
[Closed] 2012 XT - reset pads query, or something different..?
ok..
moving a 2012 XT front brake from bike to bike, the bite point is now very very immediate, and the brake howls like a banshee..
I'm not aware of altering any settings on the brake, I could have possibly squeezed the lever a little while cleaning, but not enough so that the pads rub the disk..
any ideas on what this could be or how to fix it..?
I've googled a pad reset and Park talk about undoing the retention clips, letting oil out and summoning a demon using black magic and sacrificial virgins.. is there any harm in pushing the pistons back with a flathead screwdriver..?
Posted : 27/07/2012 1:46 pm
Thats what I did on my 2012 XT the other week when my dad squeezed the lever with no wheel in and it worked just fine.
Posted : 27/07/2012 3:23 pm
Do not use a screwdriver on the pistons. They are ceramic and don't like sharp metal objects pressed against them.
Posted : 27/07/2012 3:28 pm
plastic tyre lever is ideal or lever between and old set of pads
Posted : 27/07/2012 3:29 pm
ok.. pistons pushed back, bite point adjusted, brake working superbly..
all accompanied by an ear-splitting wail.. ๐Ÿ™
The back brake is as smooth and silent as ever
Posted : 27/07/2012 3:50 pm
Clean your front rotor?
Or oddly enough dirty it with some mud, this sorts out sqealing brakes for me
Posted : 27/07/2012 3:53 pm
Calliper centred perfectly?
Have you moved rotors from bike to bike too? No idea why, but I've always found that swapping brakes but not rotors often ends in screeching from shimano. Spraying water on the pads after running them for a while often sorts it for a bit, but I never found a long-term solution other than to change the pads.
Posted : 27/07/2012 4:46 pm
Clean rotor, lightly sand pads, make sure caliper is aligned properly.
Posted : 27/07/2012 7:31 pm
after trying all of the fiddly stuff over and over again to no avail, I took my bike to the highest point around and then roosted the long road descent back down..
turns out that giving the pads a very hot bedding in did the trick, problem solved..
I've not had experience of pads needing bedding in again like that.. strange shizzle
Posted : 01/08/2012 11:37 pm
