2012 Marzzocchi RC3...
[Closed] 2012 Marzzocchi RC3 Ti, 170mm only??
[#3776625]
Right so, i'm keen as mustard to get a pair of these to go on an SB66 but worried that the new 2012 model is 170mm only???
I know the 2011 were 160mm but it seems 'zocchi aren't giving the option for the 160mm for the 2012 fork.
WOuld consider a 44 RC3 which is 150mm as the travel is fine, but i'm concerned about the chassis not being up to scratch, especially after being used to riding a Fox 36 for 5 years.
Anyone know any different?
Posted : 15/03/2012 5:12 pm
Just run a little more sag, very easy to do with air preload.
Posted : 15/03/2012 5:20 pm
Yeah but that front wheel will be a pain to hop over anything!
Posted : 15/03/2012 5:22 pm
 jedi
i have both 55 rc3 ti and 44's 🙂 oth rad forks. why would sag make unweighting the front a pain???
Posted : 15/03/2012 5:31 pm
Well, i asked whether or not zocchi were doing a 160mm version of the 55 in conjunction with the 170mm and someone instead suggested to run more sag. SO that would mean running more sag than what i would already run on a 170mm forkhat would mean that the fork would be sitting more into its travel so to pick up the fron end would be that little bit more diofficult as you'd be picking up the slack, so to speak.
I know its a minor point as DH forks run slightly more sag, but then again picking up the fron wheel when you are going at speed is easier than on a trail fork where you have to pick up the front wheel at much slower speeds.
Posted : 15/03/2012 5:47 pm
iirc the 44s are interchangeable between 140-150 with some internal jiggery pokery are the 55s similarly adjustable?
Posted : 15/03/2012 6:00 pm
 jedi
unwieghting the front has nothing to do with sag really
Posted : 15/03/2012 6:17 pm
Jedi, you're right, i guess the two points are independent of each other, but not always. Take two extremes, A v10 with optimal sag at the rear running fairly slow rebound and a hardtial. Which is easier to pick up? If you are sitting /more' into your travel that means that to lift the front end you have to effectively lift out the bit of fork stanchion inside the lower as sag, before you begin to pick up the fork/wheel off the ground. As i write this i realise its a minor point, but when you are picking up the front at low speeds its harder than if your fork was sat into its sag at optimal levels.
Posted : 15/03/2012 7:05 pm
I didn't want a fork longer than the 160mm Fox I had... so i bought a 2010 Bomber 55 RC3 Ti ( it helped that it was cheaper... I love cheaper ).
Posted : 15/03/2012 7:06 pm
 LoCo
I'd be more concerned with bottoming the forks out/ them being too 'soft' as a result of having to run 'too much sag'.
You could argue that this could be compensated for by damping adjustment, however it's not an ideal situation, setup wise.
Posted : 15/03/2012 7:08 pm
I agree with Loco that too much sag due to over soft srings is bad... but 10mm of travel, assuming 30% sag means the fork is only 6.6mm longer. If your frame has a 1.5" head tube you could run an internal headset and run the 170 fork?
Posted : 15/03/2012 7:15 pm
