2011 Rock Shox Reve...
[Closed] 2011 Rock Shox Revelation XX reducing from 150mm to 140mm?
 Leku
Can this be done? I heard that you can't reduce the travel on dual air models?
Is this right?
Posted : 03/06/2011 9:02 pm
You heard correct. Dual Air models cannot be reduced in travel.
Posted : 03/06/2011 9:24 pm
 Leku
cheers
Posted : 03/06/2011 9:27 pm
Is that true of the reba rl modle too?
Posted : 03/06/2011 9:34 pm
It's confusing, you actually mean 'Dual Position Air' - with the normal 150mm 'Dual Air' Revs you can adjust them to run at 150/140/130mm, the spacers come in the box.
So basically with the Revs that don't have the two-stage travel adjust you can't reduce travel, but with the ones that are just a simple 150mm one, you can.
It's kind of confusing that RS has come up with two labels that sound virtually the same, but there you go.
Posted : 03/06/2011 11:42 pm
 mboy
What BWD said...
Been trying to make sense of Rockshox's 2011 fork range over the last couple of days cos I'm considering an upgrade. I'm after a 120mm fork with top of the range damping (so it's an upgrade from my current Motion Control Revelation), and its been quite confusing!
But as per previous years, it seems all "Dual Air" forks are still internally adjustable with spacers, but the new "Dual Position Air" forks have 2 presets of travel, and can't be adjusted otherwise.
Posted : 03/06/2011 11:46 pm
 Leku
so to recap..
these CAN be reduced to 140mm..
Travel - 150mm
Weight 1636g (3.61 lbs)
Damping XX Motion Control, Dual Flow rebound
Spring - Dual Air
Adjustments - External Floodgate and Lockout / Spring via Air Pressure,
Steerer - 1"1/8th
Crown Forged, Hollow 6061 T-6 Aluminum
Upper Tubes 32mm, 7000 Series Straight Wall Aluminum, Low Friction Anodized
Lowers Magnesium
Post Disc Mount
Drop-out 20mm Maxle Lite
Recommended Rear Shock Monarch and Ario
Maximum Rotor Size 210mm
Color - White
Remotes XLoc
Posted : 04/06/2011 8:31 am
[url= http://www.sram.com/rockshox/products/revelation-xx ]http://www.sram.com/rockshox/products/revelation-xx[/url]
Yes, I have those and they come with the spacers you need to reduce travel. The ones you can't reduce in travel are the 'Dual Position Air'.
ps: click on 'specifications' on the page above and it actually says: '130/140/150mm Dual Air'
Posted : 04/06/2011 8:37 am
That's annoying....i was told by our rep that they can't be reduced!!!!
Posted : 04/06/2011 2:51 pm
 Leku
my mate was also told the same thing lat week (??)
Posted : 04/06/2011 5:11 pm
theoretically you can space them to anywhere within the travel range if you make the spacer yourself..
Posted : 04/06/2011 5:13 pm
