As title looking to do a cheapy lower service on my forks whats needed oil wise that kind of thing?
15wt oil
Cheers Cruz, what amount in dual air?
Looked on SRAM website but it says 5ml only in each leg that seems a bit low?
I see on the various service methods you apply grease to the seal, what grease can i use , i have super web grease and normal litium weldtite and finish line teflon/ceramic . Will they do or does it have to be fork specific like stendec that kind of thing?
Check the bottom of the air leg, you might need a deep 10mm socket to undo the lockring. (can't remember if that came in 2010 or 2011)
got the socket, just grease query as above
I use RSP Ultraslick personally. Got it from TF Tuned IIRC.
I heard lithium is bad for the seals, but don't know if that's definitely true. Would think super web might be a bit more sticky than is ideal. The Ultraslick is very very slippy grease.
I soaked the foam rings on my Rebas in Fox float fluid, and mixed a little in with the oil for the lowers. They do seem more supple, but that could be all in my head!
Thanks.
Just bought some Rock n Roll Super Slick.
