increasing stem len...
[Closed] increasing stem length
 bonj
[#3244200]
I'm planning on going from a 65mm stem to a 90mm to try and increase stability on technical climbs - but the one i'm looking at is 17 degrees rise as opposed to my current one which is probably 6deg rise, will this accentuate or lessen the difference?
Posted : 14/10/2011 12:25 pm
[url] http://www.brightspoke.com/t/bike-stem-calculator.html [/url]
Posted : 14/10/2011 12:44 pm
It will lessen the difference. You really want to get the front end lower - both for climbing and keeping weight on the front for cornering.
Posted : 14/10/2011 12:55 pm
65-90 that's quite a jump, I'd try something inbetween, can you borrow a mates to try?
Posted : 14/10/2011 1:02 pm
I was happily riding my On One when a pal pointed out my stem was very short and doesnt that make it very twitchy.
No seems OK to me was my reply...
Ever since I cant get out of my head how twitchy it is, felt fine before he said anything.
My heads been messed with.
No wonder they call them 'A-Head' fitting.!
Posted : 14/10/2011 2:24 pm
Haha, I have this with tyres, they're fine untill someone tells me theirs are better.
I ran my 456 with a 90mm stem, spolied it a little. But 65mm to 90 isn't that a big jump, unless you find an 80mm one, but then the difference might not be enough to notice.
I'd just try 90mm, hate it (O-O's are designed arround small stems, they compensate with longer TT's), then go back to 65mm (which is still longer than my 50mm on the 456).
Posted : 14/10/2011 3:06 pm
