Is it possible to 'step' these forks down by 10mm to get a 90-120mm fork? If so, they'd be perfect for the bike I have in mind.
Thanks in advance
Posted : 29/10/2012 10:27 pm
bump for the day crowd?
Posted : 30/10/2012 4:37 pm
not sure - i was going to ask the same about the fox 32 110 - 140. that is, can they be reduced to 100 - 130?
Posted : 30/10/2012 5:07 pm
I don't think you can with the u-turns. I have done it on a 2011 Dual Position Air spring.
Posted : 30/10/2012 11:22 pm
Can't remember what the air spring is like on my U-turn revs. I'd just run a bit more sag or -ve pressure.
Worst case is don't wind it all the way up to 130mm and leave it at 120mm.
Posted : 30/10/2012 11:26 pm
Troutwrestlet.How did you do that.After speaking ti Si at loco he said it was not possible on the DP revs.You need the new 110-140 internals.Be interested on how you did this bud.
Posted : 30/10/2012 11:57 pm
