2010 Marzocchi 55r ...
[Closed] 2010 Marzocchi 55r Bomber...self service yes or no? easy?
Is a service and seal swap easy enough to do on these and can you even still get a service kit for them?
Posted : 03/01/2015 10:47 pm
Yep seal kits etc still available, it can be done yourself but it's only bike parts I don't do myself for fear of bodging it......not too expensive on the Bombers but my more expensive forks I'd cry ๐Ÿ˜†
LBS did mine for reasonable sum.
Posted : 03/01/2015 10:54 pm
Yes, easy enough. Looks like CRC still do seal kits, or you could try EnduroForkSeals if you fancy something different.
Posted : 03/01/2015 11:02 pm
Are any specialist tools needed?
Posted : 04/01/2015 4:34 pm
I've not worked on the 55R forks, only the 55 RC3 Ti, but you'll probably need a thin-walled 12mm hex socket (for footnut removal) - you can grind down a standard one to fit, a few small allen keys (1,5, 2mm), a 24mm hex socket for top cap removal, preferably with the end ground square and possibly (I'm not sure about this for your forks) a Shimano cassette locknut tool (for the RH top cap).
Plus something to press the new seals in (I used some PVC pipe of the right diameter) and a flat bladed screwdriver to remove the old seals.
Posted : 04/01/2015 7:17 pm
Google doesn't seem to throw up any videos for the job..are there any?
Posted : 04/01/2015 7:27 pm
Posted : 04/01/2015 7:33 pm
This video is for the 44 but you might find it useful -
http://www.pinkbike.com/video/242073/
Thinking about it, both your footnuts might be allen bolts, as you won't have the compression adjustment there that the CR and RC3 have.
*edit* Apparently they're both 15mm.
I'll email you some info.
Posted : 05/01/2015 9:17 am
