Well that settles that then. 😀
have been running a double on my hardtail for a year (42 30 chainrings and 11-34 cassette) perfect for most conditions. Up to now ran triple on the full sus but in the process of changing to 10 speed with 40 28 rings and 11-36 cassette.
we were in italy recently and the constant shifting from middle to granny on the full sus really annoyed me hence the change.
how can it not be relevant, in every gear I'm going further than you, I'm going to get to the ice cream van before you everytime...
The point is that unless the trail is really easy then you're not likely to use such a hard gear off road.
Forgive if I'm mistaken (it's very possible), but are gear inches not the distance travelled in one revolution of the crank, there is no need to multiply by anything?
Either way, you are coming across as a bit of a moron, there's no way you're spinning out 44/11, so your analogy is baseless, except possibly on a road, which isn't how most people have their MTBs set up. My road bike has a 53t big ring, but I'll wager it wouldn't be quicker in the singletrack than my MTB!
If you are spinning out 44/11 you need to become an XC racer, because virtually no pros are running bigger than 42, and an increasing number are running single rings of 36t or so.
36t front and rear cassette of 11-34 worked great for me on my old bike. I'm just finishing building my new MTB up with 34 front and 11-32 back. Running a jump stop and bash ring to keep chain on. OLd bike had a chain cage. Would not go back to anything else. My 29er has a triple, the 22t cog is just plain useless. I have never gone in that cog in my life on anybike (honest) In like 20 years of MTB! I also live in Yorkshire wich is hardly flat! I have just stuck a 26t 36 and 48 on my 29er and 11-28 cassette on the rear. This is mainky as its going to be running 38c tyres and been used as a cyclo cross style bike for the winter. plus its rigid and very light and will be used mainly for road riding. Wide tyres and heavyish bikes for all off road type of riding just run a single ring! I did try 36t front and 11-32 back on one bike and it was hard wor on steep long climbs. Changing to the 11-34 made a big difference though.
Njee - google it. You're mistaken 😉
Sod it. Here it is 😉
Gear inches has no current physical significance; it corresponds to the diameter in inches of the main wheel of an old-fashioned penny-farthing bicycle with equivalent gearing. An alternative gearing measurement is metres of development, which corresponds to the distance in metres traveled by a bicycle for one rotation of the pedals. To convert from gear inches to metres of development, multiply by 0.0254? (often rounded to 0.08).
http://en.m.wikipedia.org/wiki/Gear_inches?wasRedirected=true
So it's the equivalent wheel size if you were running it on 1:1 gearing
Anyone got any good links for any jump stop devices that are actually cheap and work on a 1x9 set up. I have done it on the cheap with the outer ring repositioned into 2nd chainring position to keep central chain line and give less side to side stress on the chain when running at extremes but drop the chain 10 times on each commute, doesnt matter if I am pedalling or what gear I am in. Chain is at its shorteset lengeth for the largest ratio front and rear so am guessing its either a guide of SS specific front ring.
36/22 x 11-28cassette... jobs a good 'un
Better to get a SS specific ring and N Gear Jump Stop Suggsey
Suggsey - Member
"Anyone got any good links for any jump stop devices that are actually cheap and work on a 1x9 set up."
Depends what you mean by cheap, but the Superstar one works well. It's a pretty blatant copy of the E13 one after all.
Cheers for that just found some cheap DMR Chain Cages but for not that much less than a SS front ring and the N-gear.
My brother has top-end chain cage made by me on his commuter, a jubilee clip wrapped round the seat-tube which holds a wee bit of bent steel (also a jubilee clip). Ugly as sin even before it went rusty but it works well.
I've gone back the other way - ran 2x9 (36 and 44 with a wide spaced cassette) for years but have just recently fitted a triple. Enjoying the change tbh.
I have a 1x8 on my big bike that is **** miserable on the climbs but still just about acceptable, as I can't be arsed fiddling with a front der and getting it to work with the chain device.
[i]Either way, you are coming across as a bit of a moron [/i]
Coming from some-one who doesn't understand the concept of gear inches, and simple physics.... 😉
[i]there's no way you're spinning out 44/11[/i]
Didn't say I was. but I do use the outer chainring, a lot. I like going fast, and a big ring calms the back of a hardtail through the rough stuff. I like triples, versatile, no real weight penalty, all good.
Explain that one. You mean a big gear rather than the big ring, surely?
Oh and the premise of you always being faster because you have a bigger chainring is silly unless your trails are all silly fast so that the double would spin out, or as they're more commonly known, roads 😉 otherwise, you're saying that if I stick a 52 on my chainset I'll always be faster than you despite the obvious issues of being overgreared.
I've seen some nonsense posted on this forum, but really.
You wouldn't want to mix a chainring that's too small to calm the rear end of a hardtail with [url= http://www.singletrackworld.com/forum/topic/quick-tyre-question-1#post-1924941 ]tyres that suit a naive riding style[/URL] 😉
Good work clubber.
Mixing two completely nonsensical statements from on here within the last week to make one large statement of garbage.
I am applauding.
You got my hopes up for a second, I thought Nickc was to blame for both!
So does Steve Peat, but he's not running a 44t chainring, you must be quicker.
My 36 / 11 top gear I can spin to 25+mph. Thats fast enough for me off road.
The difference between a 22 / 36 / bash and 22 / 32 / 44 is that you lose the top two gears only.
How often do you use 44/11 offroad?
Blimey it's 6 teeth, no need to quite so wound up about it guys. Maybe you should ride more or drink less coffee?
You're the one making ridiculous statements, it's you vs the world, perhaps you're wrong?
I'm not the one calling people morons eh, njee?
Tj I use my outer ring quite a lot. I'm 44:11 at least a couple of times a ride. Perhaps you guys need to try a bit harder? 🙂
nickc - Member
I think we can take that as an admission of guilt 😉
Cheeky edit from '4 teeth' there, struggling with basic maths?!
I like to think of myself as 'identifying morons', rather than calling people morons, the latter implies I'm wrong.
Have you told Nino Schurter, Julien Absalon, Steve Peat and the Atherton Brood that they'd win more if they used bigger chainrings yet?
Simple marketing?
It's early. Pre noon on a Sunday you're lucky my sentences are even coherent. Right it's sunny I'm going for a ride. I may even use my big ring.
nickc - MemberTj I use my outer ring quite a lot. I'm 44:11 at least a couple of times a ride. Perhaps you guys need to try a bit harder?
Do you race at a serious level? Or do you ride easy doubletrack only? - thats 30+ mph - unless of course you are just turning the pedals at a slow cadence. I fairly often will go over 30 mph but I sure as hell aint pedalling.
I run 1*9 with a 32 up front and an 11-32 cassette at the rear. I've been running this for a year now and only on a couple of occasions have I felt I needed something more. For my local rides it's perfect.
Using M970 crank arms with a Blackspire downhill ring, e13 LG1 bash and guide with an X0 rear cassette and short cage mech. Works a treat especially now the crank arms have stopped creaking!
1x10 for me next year, 33t rotor ring with 11-36 cassette, on a 29er, not sure which tho......
I like my 1x9 for simplicity but thinking of trying a 36-11 cassette as I am not strong enough to push 32-34 on the steeper stuff for any length of time. (fat panter)
I rarely use top even on a 1x9 unless on the road
Depends on what you ride i guess. In my case: Very little 🙁
Used to run 2x9 on my 456 for a couple of years - 22/36 with a 32:11 cassette. It felt no different to a triple really, other than the gap between a couple of the ratios were a little too big.
Since then I've got fitter and stronger and I'm running a Ti456 SS (hence the fitter and stronger bit) and I've just converted my 5spot to 1x9, running 34T chainring and 32:11 cassette. I lack a little bit of big ring speed for fast descents, but I'm not over bothered by that, since absolute speed isn't really what I'm about, and it can be a bit harder up the climbs, but its no way as hard as a SS, so thats fine really.
I clocked 37mph using the big ring - but I'm sure I wasn't using the 11T cog - and it was straight downhill doubletrack - so easy stuff - I can't imagine using 44/11 and spinning out on anything remotely interesting offroad. 1X9 now anyways - in the twisty woodsy singletrack I like to ride - 1x6 on a single speed hub is starting to make sense 🙂
nickc - Member
"Tj I use my outer ring quite a lot. I'm 44:11 at least a couple of times a ride. Perhaps you guys need to try a bit harder?"
And how fast is sir spinning when in that big gear? I know lots of people who use the 44:11 offroad but I've never seen anyone [i]have[/i] to use it on anything that was at all interesting to ride.
So im gonna give this a try 1x9 and not got a clue what I need.
can someone advise please
SLX double at the mo with a SLX 32/11 cassette and chain
I think just take off your smallest ring, add some kind of chain guard and remove mech and shifters no? shorten the chain too?
If you are switching to a single ring up front you'll most likely need a chain device (superstar have just brought out some reasonably priced ones) or you could keep the front mech and use that.
Most likely you'll be dropping the bash as well so some shorter chainring bolts
You could keep the middle ring but would be better off with a single specific ring like a middleburn or e13
Shorten the chain
Job done.
I've use 1x9 - 34t 11/34 on my fun bike and 2x9 26t/36t 11/34 on my XC bike. Once the 36t wears out I'll be prob getting a 40t
I only miss the big 44t on the road.
