1x9, 2x9(+ bashguar...
[Closed] 1x9, 2x9(+ bashguard) or 1x10 with Hope Trex?
I'm currently running my Superlight 29 with 1x9, with a 30t hope narrow/wide, and an 11-34 xt cassette.
It's fine for an hours ride on my local trails, but over an hour the grinding uphill really takes it's toll. I live in a hilly area on the outskirts of the Peak District, so i need some lower gears or bigger legs!
Question is, should I put a front mech on my bike, and run a granny ring (I have an X0 shifter and my old triple chainrings, all i need is a mech and a bashring/single ring fixings - don't want a big ring)? Or stick with the 1x9 and hope i get strong enough to push the gear all day?
I could upgrade to 1x10, but to get XT level its going to cost close to £200... Also, I'm running Sram X0 shifters and rear mech at the min, which I think are rather nice. 🙂
Anyone else think its a shame no one makes a 9 speed 40t cassette adapter?
Posted : 13/07/2014 12:52 pm
Find some bargains to upgrade to 10sp and sell your 9sp off. I was surprised how much I made off the cost of my upgrade when I did it.
Posted : 13/07/2014 1:09 pm
1x10 all the way
SLX RD is just as good IMO and nearly as light...but get a saint shifter from evans for £35
Posted : 13/07/2014 2:24 pm
1X10 all the way, just converted from 2X9 and I shall not be going back any time soon. Might keep the front mech for when they become collectable, show the kids how they used to make bikes 😛
I'd also recommend budgeting for a One-Up rad cage, resolved the issues I had with dodgy shifting on my xt mech, 40t expander setup.
Posted : 13/07/2014 3:08 pm
Have to admit, 1x does look better, and reduce clutter on the bike.
I'll budget for some new shiny bits when i get paid at the end of the month. TBH, a shadow+ mech would be a good upgrade too as the sram xo has no clutch of any kind.
I'll check out slx too, it may save a bit of cash.
Posted : 13/07/2014 6:36 pm
I picked up an almost new XT Shadow+ mech someone swapped out from a brand new bike for £25, you'll easily do it for under £200 and recoup some back if you sell your 9 speed gear
Posted : 13/07/2014 7:05 pm
I was thinking about this when building up my new 29er. I stuck with 2x9 because 1x10 doesn't offer anywhere near the climbing ability, even with the T-rex, etc.
Admittedly I live in Scotland but I'd hate to have to push 1x10 up some of the 2h+ loose and steep hill climbs around here! So I guess it depends where you live (or maybe I'm not herculean enough).
Posted : 13/07/2014 7:55 pm
I went 1x9 with a chain device to 1x10 with a N/W setup. Cost ~£100 for Zee shifter, SLX mech, cassette & chain and a Race Face N/W ring. £40 of that was the ring IIRC!
Great upgrade - wider range of gears and less weight. Whats not to like? The only time I've ever really wished I had a lower gear was after a brutal 6 hour ride in torrential rain in Wales and the final short climb to the pub had me pushing...
Posted : 13/07/2014 8:01 pm
Really pleased with my 1x10 (because I'm as enduro as ****) but I reckon dual ring is still the default and for good reason... Only you can really know what gears work for you, and only by experimentation. So if I was you, I'd put it back to 2x9 and see what happens.
Posted : 13/07/2014 9:24 pm
Or just get a 12-36 9 speed cassette and see how it goes for a lot less cash.You can swap the 12 t for the 11 t you've already got if a higher gear matters to you.
Posted : 13/07/2014 11:09 pm
12-26 is a smaller range than 11-34. You can mod them with an 11t but (depending on how lucky you are with parts) it can be hard to get it to work.
Posted : 13/07/2014 11:10 pm
No argument on that one 🙂
Posted : 13/07/2014 11:15 pm
Did you sneaky edit or am I losing it? About 50/50 which way this goes 🙂
Posted : 13/07/2014 11:17 pm
I have a mate who seems to be getting away with a 40t on 1x9.
I haven't seen it in the flesh, but that's what he says.
Posted : 13/07/2014 11:19 pm
Northwind
I edited and added the bit about the 11t simultaneously as you posted,honest.
IMHO range is not the issue for most riders who go 1 x it's about having an easier gear to get up the hills.
Posted : 13/07/2014 11:24 pm
I've got 1x10 (12-36 cassette, 32t ring) on my hardtail and it's OK but I spin out on the fast pedally stuff and I end up walking steep climbs when I'm tired. An expander thing might help but it's all a bit of a bodge and not cheap.
Full suss is still 2x9 (12-34 cassette, 22/34 rings) with a stinger. This gives me all the gears I need and I never lose the chain.
Until 1x11 becomes affordable I'll my preferred set up will be 2x9
Posted : 13/07/2014 11:25 pm
1x10 all the way.I'm running 11-42 with 32 up front and it's ace.
Posted : 13/07/2014 11:50 pm
No 2 hour climbs here, but plenty of steep,technical stuff and 30min climbs.
I think £20 for a new front mech may be worth a try first... I am worried that 1x10 with an easy gear is going to be expensive, and still wont be low enough for steep, technical climbs...
Posted : 14/07/2014 12:19 am
I went from 2x10 down to 1x10 with the Trex and 34t ring. Works well for me, the 34 helps with the spinning out issues but not as much as having a 10t at the back. The 40t is a nice low gear but not a granny spin.
Also going from X0 9sp to SLX 10sp will be very noticeable, and potentially not nice, tried some demo's with it on and not that impressed.
Posted : 14/07/2014 12:27 am
It's well worth upspeccing the shifter, the 10-speed Saint isn't much more than an SLX but it's in a different world. And if you're a 9-speed SRAM guy, luckily Shimano have now stolen all of SRAM's good ideas and superior feel 🙂
Posted : 14/07/2014 12:58 am
Non existent on the SLX level stuff and hard to tell on the XT I tried 😉
Posted : 14/07/2014 1:04 am
I just got zee mech and shifter plus a roadie 10spd cassess and chain for £77 on crc so it can be done very cheaply indeed.
Posted : 14/07/2014 7:14 am
http://singletrackworld.com/forum/topic/4042-t-conversion-adaptor
Posted : 14/07/2014 8:28 am
mikewsmith - Member
The current XTR seems to have the classic Shimano broken-cable feel too. But saint, mmmmmmm. So much like my old X9, proper bolt action.
Posted : 14/07/2014 9:10 am
