Last year I was running 1x10 on both my train and xc bike and felt that, not having the fitness, I missed the low end (I was running 11-36 at the back) for the steeper stuff when tired.
This year I've upgraded to 1x11 xt on the trail bike and although I'm liking having the bail out option of the 42 tooth cog, I find that I'm always in the wrong gear, either spinning to much, or having to push to big a gear.
Whislt its not a problem on the trail bike I'm having second thoughts on converting the xc bike...anyone else gone back to a double set up with a smaller cassette to minimise the jumps between ratios?
TBH, it's one thing that puts me off. I've always liked nicely stacked ratios for racing. To the extent i've almost always used large road cassettes for racing on the MTB. I'd like to see a smaller 11 speed cassette with nicer gaps (11-34 or 36 maybe) to run with the new x000 series shimano stuff. Either single or double ring.
I doubt it'll happen tho.
yeah I posted that with one eye on a few races this year. The kind of thing I do (gt7 etc) requires a low gear for when you are knackered at the end of the day and the only thiing that puts me off is the weight penalty on my 20lb bike - that and the fact I'm going to have to try to run a cable back through the frame if I go back to a double.
What's it cracked up to be?
By contrast to ghostlymachine, I'm more interested in having a wide spread of ratios, but I don't race and I only generally ride significant distances as a function of getting to interesting terrain.
My perception of 11 speed is that it gives me the same bottom and top as my 10spd with a 42 adaptor (talking shimano here) and another ratio in between to fine tune. I can't see that giving me any performance benefits approaching anywhere near the outlay required.
Like most things with bikes, it depends what you want.
1x11 is shit.
1x12 is where it is at, 10-50 cassete 8)
Just be careful if you buy a new Orange 5. They are 1x only now.
I can see it might be an issue for XC if you are racing. For general MTB rapidly changing terrain means there is no perfect ratio. I find it means I'm in the right gear far more often.
Possibly one of the least sensible purchases for XC racing.Just be careful if you buy a new Orange 5.
And TBH, the latest shimano side swing mechs, if they are anything like the new road ones, will shift as fast as you can blink. And they need a new cable routing anyway.
So not *really* a major issue.
Go singlespeed, and wonder how people were ever convinced that spending more money on a cassette than you can buy a perfectly functional bike for was ever something they had to do!
I'd not realised we were discussing it solely on the race bike sorry.
Yeah, I like it- all my bikes are 1x of some sort, 9 to 11- but I'm completely unfussed about "perfect" gearing and I don't really like close ratios. I had a close ratio'd road bike and dh bike and I just ended up doing loads of double shifts. So 1x suits me very well, I'm oblivious to what other people might find are downsides.
If it's something that you know bothers you then obviously you should stick with the closer ratio'd options rather than switching to a system that's specifically designed to have wider gaps; but o'course not everyone knows if they like it or not.
Most of the chat focusses on gearing range, it just happens to be the easiest part to grasp and talk about, so it dominates even though for some folks it's probably not the most important thing.
tpbiker - Memberyeah I posted that with one eye on a few races this year. The kind of thing I do (gt7 etc) requires a low gear for when you are knackered at the end of the day
I've used a single ring to solo the 7 for the last 2 years and will do this year too. Not that I'm in any danger of winning mind 😆 But it's fine for my weekend warrior legs.
Tpbiker - have you tried running a different size chainring?
I've never really had this problem myself - only when using my race bike for commuting when I wished there was an 11 between the 10 and 12...
But for xc race use I find it perfect. At one race last year I actually used every gear, which was a bit of a rarity for me. When I ran 2x10 I dont think I ever used 42x11 or 28x36 in a race
Again, it depends on the racing, and where you are, as to what gears you need.
I suspect a short course, lots of ups and downs/wiggly/techie stuff it'd be ideal. Even for the fussy amonst us 😉 )
Anything with any long drags (up or down) and/or a more spread out course it'd drive me mad, always felling that i could be a *bit* more powerful or efficient in a slightly higher (or lower) gear. But not having that gear.
And FWIW, i've done a couple of marathons where i've used every gear on a 2x system.
Pretty much agree with the OP. 2x10 on my X/C marathon bike and 1x11 on my trail playing in the woods bike. I'm pretty cadence sensitive and there's definitely a couple of either to spiny or to hard gears on the 1x11. Not a problem for general riding but would be annoying for racing. As an aside with 29'ers the lowest 32x42 ain't that low, it's taking a bit of getting used to.
But am I right in thinking you've never tried it?
The jumps aren't that massive... No worse IME than those on a regular 2x10, just without the duplication!
Yes, i've tried it. Went to 2x instead. Get pretty much the same range. But more steps.
For me the problem is that the gears are too closely stacked. I often feel that there isnt a big enough difference between the ratios so end up doing multiple shifts
Like I've said before, 1x is not the saviour of biking and is not an upgrade, it's simply an option. It has benefits and draw backs, same as 2x or 3x.
Must admit I'm far more cheesed off about manufacturers dropping the ability to use front mechs then I was about a change of wheel size. At least with the wheel size you can actually notice a difference. Whether you like the difference or not is up to you.
I wasn't convinced by 1x when I tried it last year. I found I was always clicking through the cassette to find bigger gears rather than a nice quick chainring change. Going to easier gears was no problem because you can change several at a time. The big difference for me was going to shimano where you can downshift two at a time. That made the whole thing make much more sense and now all my bikes are 1x11 with shimano shifting.
If I had my ideal set up I would have a 8 or 9 speed but with the range of the 11 speed. The bigger end of the cassette would be quite closely spaced but the smaller end would have far wider spacing. That seems to make the most sense to me.
For me going 1X10 involved removing one sprocket from an 11-36 and adding a 42 so the majority of the cassette remained exactly the same. Maybe close ratios are good for racers who work best at a very specific cadence but it isn't a problem for everyone.
I'm 28 front 11-42 on my trail bike and 36/22 11-36 on my XC bike. Works for me! 🙂
Well yes on the ratio side, going 2x10 SLX to 1x11 XT with Abs Black Oval took just index 1/2lb off my bike
I've used mine for two races and - not being a climber - at Hadleigh also which is all about rapid geographical and therefore gear changes and lots of climbing.
No issues with sprints, overall pace or climbs for my ratios (42/11 & 34T Oval)
1x is outselling 2 or 3x for us by 10-1. Yes we offer 2x on all our bikes but I can see why some don't.
[i]yeah I posted that with one eye on a few races this year. The kind of thing I do (gt7 etc) requires a low gear for when you are knackered at the end of the day and the only thiing that puts me off is the weight penalty on my 20lb bike - that and the fact I'm going to have to try to run a cable back through the frame if I go back to a double. [/i]
I can imagine that you'd suffer on the climb through the Freeride with 1x if you'd only a 11-36 cassette, especially late on unless well fit.
FWIW I've done it the last few years on a 3x9, and needed the granny on the steeper sections - but this year it'll be 1x11 with a 32 oval and 42 cassette, so we'll see...
My 1x11 sram is better than my 1x10 expansion, better than 1x10 non expanded and a lot better than 1x9. I also prefer it to 2x10 for riding, racing and having fun. Can't actually remember riding a triple so can't compare though I vaguely remember that being about being in the wrong gear constantly or changing to find it was the same gear...
I reckon most of the serious guys racing here tomorrow will be on 1x11 and not have a problem
Just gone 1x11 XT 32F with 11-42R after being 1x10 XT 32F with 11-36R. Wish I'd done it much sooner. Such a relief to actually spin on steep climbs instead of mash, stop, mash or just push. Shimano will get my money for the 46T XT cassette just announced too especially if it has a 38 or 40T 2nd gear and doesn't need a new mech (don't believe it does).
Anyone who knows Llangollen knows it's just steep in every direction to get to the good stuff.
Doug, are you running an XX1 cassette with XT 11 speed mech and shifter.
I pringled my mech yesterday and was just about to press that big BUY button on that exact combo.
Also interested to hear.....well GX cassette and XT shifter in my case
Hi Mac, I'm on shimano cassette too just now. Apparently there is no problem mixing but I was starting from scratch so just went the full Shimano.
Coolio, cheers doug 🙂
You only need to match Mechs and Shifters (and even that can be bodged) everything else is interchangeable.
EDIT - I've kept 2*11 on my trail bike running 28/38 and 11-40. I like to pedal on the downs and spin on the ups. 2* works better for me and lets face it, an extra 200g is nothing to be concerned about.
[I]an extra 200g is nothing to be concerned about. [/I]
It'll be twice that: shifter, front mech, smaller front chainring, front cable and outer etc
b r - Member
an extra 200g is nothing to be concerned about.It'll be twice that: shifter, front mech, smaller front chainring, front cable and outer etc
Nope.
XTR M9000 DM, 2* Front mech - 118g
XTR Shifter + cable and outer 121g
XTR Front ring 36g
So, 275g if you're being a pedant. 🙂
Plus a few more grams and pedant points for the longer chain running 2x 🙂
Maybe some extra weight to be saved chopping off cable guides and granny ring bosses plus 4x steel bolts.
And some of us aren't running XTR weight kit.....
[i]So, 275g if you're being a pedant. [/i]
At the minimum that rounds up to 300g, not 200g 🙂
tbh I swapped from a 3x9 utilising XTR shifters and front mech, XT rear mech and XT chainrings and cassette to 1x11 using XT, keeping the old cranks and just adding an oval ring.
Barely saved anything as the XT 11-42 cassette weighs 450g...
b r - Member
So, 275g if you're being a pedant.At the minimum that rounds up to 300g, not 200g
I never round up unless someone else is paying. 🙂
I've just moved to 1X11 from 3X9 as my 7 year old bike was nicked.
messing about on techy trails - 1X11 is great.
Most other stuff - cant see the benefit.
FWIW I love it, changing up the block dead quick at the bottom of a DH is very effective to be able to maintain momentum into a sudden up.
mactheknife - MemberDoug, are you running an XX1 cassette with XT 11 speed mech and shifter.
I can't keep track of what SRAM is what but I'm running XT shifter and mech on the second top SRAM cassette, whatever that is. XxXX2 or something. Works perfectly tbh, the cassette's a little noisy ("tingy") just because there's so little metal in it I think, but the shifting's spot on.
People say it can come off if you backpedal- like, really backpedal, not just a wee clutch. And this is true, but why are they backpedalling?
Northwind, i found that with my XT (on XT cassette). I practically eliminated it by adjusting the chainline. I can´t remember what I did but it wasn't what was advised on the BB fitting instructions.
I'm just going to ride my bike properly, that should sort it 😆
What did 650b outsell 26" by when the industry and fashion switched? As I said, different sized wheels make for different characteristics, more or less gears doesn't as within a specific window it's the same. Outside that window you need more gears.
Fashion is starting to limit the bikes I can/want to buy again but with performance drawbacks rather than garage full of 26" stuff drawbacks.
When will it end? With cassettes the size of 26" wheels? At which point someone will reintroduce front mechs and 'feather weight' cassettes and we'll all wonder why we bothered. 😐
I actually went 1x11 XTR on my Superfly, and in honesty hated it.
Really missed the range in gears, spinning was so much harder also, we specially when just wanting to cruise up hills.
Still experimenting though, don't thing my ratios are too flattering either,
I'd like to try 1x11 (currently 3x9) but can't make my mind up whether it's worth it
Pros -
One less shifter on the bars so can run reverb lever in a better position.
Over all weight reduction - 300g?
Quieter drive train
Simpler shifting
Cons
200g rotating weight to add to the back wheel
Reduced gear range, particularly on the top end
Will cost £150
Anything I've missed?
I went from 10 years of single speed to 1x10 so I didn't really 'miss' any gears apart from very occasionally a harder gear when racing xc (and then I was probably better off coasting and recovering) and certainly never wanted an easier ratio.
Gone 1x11 (xt mechs/sram cassette) and much of the same tbh...kinda miss the 11t and that's about it.
@rudedog the reduction in range is about 3 ratios (that's comparing a 1x10 using an 11-36 cassette with 40T extender against a standard 3x10 setup). Which ratios you lose depends on the chainring you choose. For a 29er a 30T chainring means you lose roughly 1.5 ratios at either end.
I'm currently running a 32T chainring and by the time I'm spinning out (a cadence of somewhere between 115 & 120 for me) in top gear then I'm well in to the range where I'd freewheel. I did start with a 30T and with that I didn't notice the jump due to removing the 17T sprocket but do notice it with the 32T. I think the jump now falls at one of my sweet spots in power.
1x isn't for everyone, a lot depends on what and where you ride. I rarely use the 40T extender or the 11T sprocket, usually if I have to get off on a climb the extra ratio or two that I'd get with a 3x setup wouldn't make much if any difference so for me a 1x setup is fine.
Exactly, 1x isn't for everyone but we're beginning not to have a choice. Granted, there are still plenty of front mech friendly frames atm.
200 grams of unsprung mass your adding to the rear wheel.
200g? Almost half a pound? What cassette are you going from/to?
If you are racing, I can see the attraction of 2x10 with a nice closely spaced cassette and a decent gap between the chain rings. For me though (and I imagine most of the market) 1x11 is great
9 speed 250gram XT to 11 speed 450gram XT, assuming the weight for 11 speed cassette is correct.
Ah, thought we were talking 10sp currently. Still, that 200g could be brought down significantly if it was a massive issue.
Fairly underwhelmed by 1 x 11. The lack of range is a pain, quite literally, on long slog and steep climbs while I run out of gears on flat roads. The SRAM 11 42 cassette with all the cut outs does a tremendous job of becoming clogged up with mud while the jockey wheels clog up in sympathy in short order. All it does is limit my options on rides with no discernible benefits.
I suspect that chestrockwell has hit the nail on the head. I'll never buy a 1 x frame as it restricts my riding unnecessarily.
Thinking of changing from 2x9 to 2x10 or 1x11 and like the idea of clutch mech and NW rings. Previously tried 1x9 and loved the simplicity but I was on lighter HT, fitter and flatter trails. Think I've got this right but 2x10 i loose about 1/3 of a gear off the low end and 1x11 about 3/4. Quite a few variables to consider including cost.
I'd like to see a smaller 11 speed cassette with nicer gaps (11-34 or 36 maybe) to run with the new x000 series shimano stuff. Either single or double ring.I doubt it'll happen tho.
What about using a Sram 11-36 road cassette? Yes, you'll need an 11spd road compatible hub but there are plenty of those and it'll work.
That is one thing i have considered, but I'll be leaving it a while. Until i can actually ride a bike again.
It should be pretty straight forward to just lace a road disc hub into an MTB rim.
I had already has that in the 'cons' list
Rotating mass isn't the same as unsprung weight, although in this case accounts for part of it.
Gears are the most boring part of a bike. Fact.
With a front mech and racing, you are wasting time faffing with front shifts.
If you struggle with the gear spacing in the few meters if trail where you adjust you cadence or power delivery, then your not really racing, youre only there to participate in an event.
With 2x, on 11-34, i want to get out of granny as soon as possible. Running through the cassette range in granny is not a good thing for me when racing. But having a fd just to allow those additional few different ratios when i can make a small close ratio sacrifice is easy to justify.
What about 1x11 10-40 with a 45t "safety" and plus 1or2 teeth on the front chainring?
Hmmm. You're either unable to set front mechs up or you've never ever done the same races as me. Or both.
Definitely the latter anyway.
Im dabbling with 1x10 and 1x11 at the moment full sus is 1x10 30t chain ring with 36 big on the cassette. Some big hills i think an expander would be nice but im making up for it with fitness. My cx bike is 1x11 the range of ratios is sorted at the extremes just a couple of the gaps take a effort to spin up to the next gear. Again i think a jump in fitness and ridding style is going to over come that.
Overall both have + - points and for me so far the + out weighs the - so far.
Oh dear - I spent a couple of hours this weekend converting a bike to 3x1
#rightofftrend 🙁
Lets say you are running 2x10. Probably compact 27/39
For a continuous ratio run, from granny, you hit mid cassette then need to shift into big ring and back to the largest cassette sprocket to not overlap.
Thats 1 chainring shift and 5 cassette shifts to not overlap ratios.
On 1x yes you might be shifting 3, max 4 teeth in 1 shift in the larger sprockets, but that's 1 shift vs 6 with 2x for the same effect.
That's wasted effort and a small amount of trail time under reduced power while making those 6 shifts to maintain a continuous ratio spread.
A 2t or 3t (2x10) vs 3t or 4t (1x11) mid cassette shift [as per parkesie] is made up for with fitness, which is surely a prerequisite for "racing".
My issue with 2x was finding the right gear as you have choices that overlap and I used to find myself in a less than ideal front ring more often than 'never' with 1x. More shifts finding whats right means less speed imo.
I've just gone from 2x9 to xt 11 as my old x0 rear shifter packed in. First ride today.
Its odd, and seemed rubbish on the road in the morning to be honest, but on the trails its amazing how quick you can get into a suitable gear.
I also found the "big-un" to be quite draggy, and not as easy as the 22x34 smallest gear on my previous set up (even though the ratio is the same) , seemed like the chain was crossed so much it added a bit of resistance and noise.
After a few hours in the mud, the dragging/noise had stopped, and I'd got used to and it didn't seem annoying on the road in the aft.
Can't really see a downside at the min, although I do miss my shiny carbon X0 9 speed kit!
I'm not sure if the xt kit is lighter than the x0 kit it replaced, but I'm sure their isn't much in it either way.
By the way, xt 11 speed mini group set is a very similar price to a 1x 10 speed xt mini group set. How have they done that!
I may be missing something here (wouldn't be the first time), but mist 2x cassettes are the same ratios (near enough) as a1x cassette. Therefore the spacing is the same. I had m8000 2x 11 with an 11-40 cassette, the 1x offering usually has a 11-42 cassette, the only difference between the 2 cassettes is the biggest sprockets, all the other gaps are the same. These gaps are in fact almost the same as as on a 11-36 10 speed casette, which is what you get with most 2x10 of 3x10 setups. Obviously you could use a road casette, but I see very few xc racers reducing the range on their cassettes. Also, and the reason I swapped to 1x, is that if you are in the granny ring it is probably quicker to walk/run!
I can see the point in 2x if you live somewhere with proper mountains, but not for racing (24h excluded).
I rather like mine, liked the 1x10 that I took off to fit the 11spd too.
My new bike comes with 2x11 and I'm seriously contemplating binning the double, front mech and 11-40 cassette and slipping on a 11-42 and a 30t front.
ghostlymachine - Member
In most of the races (xc and enduro) I've been to recently front mechs are a rare commodity. 1x is king and it works for a lot of people.
Though to show how it's more about the rider the winner of the 12hr at the weekend was on a single speed.
I'm absolutely loving my 11 speed XT so far. At the weekend up a steep snowy communications mast access road I was riding with a friend who's been riding 1x10 with 11-36 the same as I had a been using and we're very evenly matched fitness-wise. We've both ridden around for about 18 months / 2 years with 1 x 10 XT.
My knee has been hurting me recently so I took the 11 speed plunge in the hope it might help lower the stress through the knees a bit.
The ease and speed I could go up the steep horrible climb on the 42T was very impressive. I just span away from my friend on the 36. He said at the top he was trying to keep with me but there was nothing he could do.
I was expecting to go slower with the 42T and wasn't too bothered as just getting a ride in without knee pain is a huge achievement at the moment. Forget the racing etc. I just want to ride at all. In reality the 42T isn't making me slower. I'm able to carry on turning the pedals where otherwise I'd be gasping for air and stopping.
I'm actually looking forward to finding out more about the 46T XT cassette. I could go up to a 34T front ring then and gain speed on the way down without missing any of the climbing ability.
Or you could have installed a front mech and had that all along.
Whatever... my experience with a front mech was dire once I got fitter and faster... and I will never ever go back. It was pray before a front change that either the chain wouldn't get sucked in and jam between the chain stay or the chain wouldn't just jump straight off into the BB and jam in the mech.
Pre-climb set the front mech just meant you ended up spinning until you ended up at that slow speed. With 1x you power up the first part of a climb, click a few gears and you're at the top already.
So yeah... if you like 2x or 3x... keep them but for racing or anything remotely bumpy... 1x is the dogs and now it has the range and the much lower price of entry.
Really?
I just press the button and bingo, rings shifted.
Much the same as the other post up there ^^^^ If i want to go little to big (or vice versa) i just choose my moment, press the button. Then a couple of clicks on the rear mech and i'm in the next ratio. Not my fault if you get confused by having more than one chain ring.
How about I simply don't need one at all. 1x11 10-42 gives me a huge range that I can use and works for the riding I do. Even 11-42 is good but I'd prefer the extra legs of the 10t just to widen it nicely. I have 50% of the shifters and mech - saving money and weight and I have nice gear changes. I have the range of something like a 24-37 double and a chain ring that holds the chain on removing the need for some of those clumsy chain devices.
I'm sorry some of you don't like it but it works for a lot of people.
And it doesn't work for me. I've tried it. Dunno why everyone keeps trying to sell it to me based on their own experiences, which i've not had.
Praying for a shift to happen.
Hoping that it doesn't drop the chain.
Just living with a poor gear selection.
Getting confused by how ratios work and the point of a double set up.
Only there to participate, not actually racing if you are using a double (now that's hilarious and i'm sure my sponsors/employers over the years would have been delighted to hear it)
Meh. I'll wait for 1x15. 😉
And FWIW the pointy end of the last race i watched was about 1/3rd 2/3rds split in favour of singles. I suspect that will have shifted slightly this season as more and more new bikes come built as 1x.
Yeah I know the difference, I was just being more specific 🙂 .
ghostlymachine - MemberPraying for a shift to happen.
That's just setup/part selection issues tbh, 1x should shift as well as 2x or 3x (since it's functionally identical where shifting is concerned) and has better chain retention not worse.
There's totally legit reasons to not like 1x and it seems like you have enough of those, but these 2 aren't.
they are dirksdigglers reasons for not liking 2x. Not my reasons for not liking 1x. I reckon he can't set up front mechsThere's totally legit reasons to not like 1x and it seems like you have enough of those, but these 2 aren't.
That's a setup issue it's not the fault of the front mech and is not typical of other peoples experience.
Don't blame the front mech!
In 15+ years I cannot recall either myself or any of my riding friends having issues with the front mech, far more likely to have issues with rear mech, brakes, chain or indexing.
In 15+ years I cannot recall either myself or any of my riding friends having issues with the front mech, far more likely to have issues with rear mech, brakes, chain or indexing.POSTED 4 MINUTES AGO #
That really surprises me . I've had plenty of instances of people in the wrong front chainring trying to change onto the small ring but not willing to back off the power resulting in twisted or broken chains and worse . I also work in a bike shop and see plenty of evidence of this on repairs that we take in .
Now you mention it I do recall two instances of just that, changing up under power and twisting a link, the two riders involved have zero mechanical skills and zero mechanical sympathy and was most likely caused by rider/ poorly setup front mech.
It's just not as big an issue as people are trying to make out, personally speaking it's a non issue, it really is.
