1x11 new chainring;...
[Closed] 1x11 new chainring; what have I done wrong?
E13 chainset, xo mech and cassette. All 18 months old. Shifting was sweet, but the ring made a horrendous grinding noise in the 42 sprocket. It was a very worn 32t ring, I changed it for a 30t, again a e13.
The chain was slack so I shortened by two links. I measured the chain and it's just shy of 12 1/16th over twelve links so ought to be OK.
Problem: the shifting is now all over the shop. The symptom is the same as a wonky hanger, I.e I've got the full span of the cassette, but random non+shifts and double shifts.
What have I missed?
Posted : 09/01/2016 6:40 pm
Not sure, but I would check and adjust cable tension, b-screw adjustment and work through the process of setting up a rear mech.
EDIT: Further thoughts towards your chainline, is your E13 crank a dedicated 1x? Just that you mentioned noise when in your lowest gear, which could suggest you have (also) a chainline dim that is greater than the advised for a 1x11 (48 -50mm at a guess?)
Posted : 09/01/2016 6:46 pm
Yes it's an e13 1x specific crankset which came with the bike, a Canyon Spectral 29er.
Nevertheless, it does make one think. The grinding was caused by burrs on the ring which a mechanic filed off for me, to temporarily good effect. The burrs will have been caused by the chain arriving and departing from the ring at a violent angle.
Hmm.
Posted : 09/01/2016 8:39 pm
