1x10 problem chain ...
[Closed] 1x10 problem chain line and chain device XT chain set issue help please
I have just got a new XT chainset and e13 34t guide ring. I’m using an e13 chain device but it’s all out of alignment.
I’m not using any spacers on the HT2 BB but as not used to using Shimano stuff any help appreciated.
Pics below hopefully showing the problem I’m having.
[URL= http://img444.imageshack.us/img444/2944/photodov.jp g" target="_blank">http://img444.imageshack.us/img444/2944/photodov.jp g"/> [/IMG][/URL]
[URL= http://img7.imageshack.us/img7/1459/photo2kuk.jp g" target="_blank">http://img7.imageshack.us/img7/1459/photo2kuk.jp g"/> [/IMG][/URL]
[URL= http://img401.imageshack.us/img401/3811/photo3kl.jp g" target="_blank">http://img401.imageshack.us/img401/3811/photo3kl.jp g"/> [/IMG][/URL]
Posted : 26/04/2012 6:52 pm
chain ring should be on the other side of the spider, where the middle ring would be, you've put it where the big ring goes.
Posted : 26/04/2012 6:57 pm
 mboy
First things first, before anything else, YOU MUST install the chainring in the middle ring position, not the outer position. Otherwise no wonder you can't get the right chainline!
Also, what width is your BB shell?
If it's 73mm, you should have one spacer (though the arm for your E13 will count also) on the drive side, if 68 then 2 drive side and 1 non drive.
Posted : 26/04/2012 6:58 pm
Wah-wah-wah.
Posted : 26/04/2012 7:58 pm
Cheers just what I wanted to know. 456 carbon so 73mm shell btw.
Continuity - just looking for help. This is replacing my X0 chainset so this shimano is pretty alien to me.
Thanks for your help.
Posted : 26/04/2012 8:51 pm
Sorry, that came out as "wah wah I'm crying". It was unintended. The sound you were meant to hear was a three note descending
Wahhh ... wahhhh ... waaaaaaaaaaaaah
to indicate that someone had made a silly booboo.
Posted : 26/04/2012 9:45 pm
Had an issue with mine, in that the "cage" needed spacing outwards. Ended up shimming behind the cage.
Mine was Superstar XCR guide on Deore crank.
[url= http://farm3.staticflickr.com/2616/5837075263_b13ce0424b_o.jp g" target="_blank">http://farm3.staticflickr.com/2616/5837075263_b13ce0424b_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/takisawa2/5837075263/ ]IMAG0521[/url] by [url= http://www.flickr.com/people/takisawa2/ ]pten2106[/url], on Flickr
Incidentally, running SS I run the ring outside, because chainline is better that way.
[url= http://farm8.staticflickr.com/7056/6928674149_f2f90688af_o.jp g" target="_blank">http://farm8.staticflickr.com/7056/6928674149_f2f90688af_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/takisawa2/6928674149/ ]IMAG0335[/url] by [url= http://www.flickr.com/people/takisawa2/ ]pten2106[/url], on Flickr
Posted : 26/04/2012 10:16 pm
