1.8 mud tyre pressu...
[Closed] 1.8 mud tyre pressure?
2 Users
just bought myself a maxxis medusa exception 1.8 tyre to run at the back of my hardtail. will be using it for light xc eg thetford which is a bit of a slop fest at moment. could you recommend a good psi setting to start of with, i weigh about 94kg with gear on, so im no skinny whippet.
Posted : 24/01/2013 2:44 pm
I have a Medussa 1.8 - I'm 76kg and run it at about 30 - 35psi for my local trails where there is nothing really that will cause pinch flats.
As there's not a lot of volume in it you need the pressure to be a bit higher, I tend to go for feel though rather than rely on the pressure gauge - I like to have a reasonable amount of give in it.
I'd suggest trying 35 to 40psi and see how it feels.
Posted : 24/01/2013 2:54 pm
thanks, shall have a play tommorow
Posted : 24/01/2013 6:15 pm
