'17 Pikes ... going...
[Closed] '17 Pikes ... going 130 to 140mm
[#10646136]
Advice ... the change in stroke seems to be easy enough to do ... and involved parting with 40 GBP.
It is on a FlareMax, which can take 140s
Worth doing ... or will I never notice? ( I suspect the latter)
And yes, I can use up all the travel ...
Posted : 30/05/2019 11:43 am
Even more so if your going from an older type air shaft to a DebonAir.
Posted : 30/05/2019 12:35 pm
They are debonair / charge damper ...
Posted : 30/05/2019 12:47 pm
130 was supposed to be the sweet spot on the FlareMax. I'd leave it as is for the time being and see how it feels.
Posted : 30/05/2019 3:57 pm
Doubt you’ll notice the travel difference.
Make sure you get a 2019 spec debonair airshaft - they are definitely different to the 2017 Pike airshaft - I know because I’ve done the change.
If you want to check what you’ve got, the old airshaft has black plastic / rubber on the bottom of it - but the 2019 version has red anodised aluminium on the bottom.
If you take the top cap off the air side of the forks and shine a torch down inside you should be able to see if you have the whizzy red one or not.
Posted : 30/05/2019 4:33 pm
Making the circlip easier to remove and reinstall, which is an added bonus for those of us with just the 2 hands.
Posted : 30/05/2019 4:58 pm
Thanks ....
Maybe leave as is ...
They are either ‘17 or ‘18 pikes ... will the ‘19 shaft fit?
Posted : 30/05/2019 9:27 pm
Yep,but depending on the year you might need a slightly different model:
https://www.tftuned.com/debonair-air-spring-upgrade-kits-pike-yari-lyrik/p3412
Posted : 30/05/2019 11:52 pm
