I'm looking for some 165mm cranks for my lad, I can't find anything at a reasonable price. I'm after something reasonably light and not square taper if possible.
I can only seem to find XT but they're too pricey for a 9 year old!
Anyone got any ideas,
I got some zees in 165 from tweeks the week before last for £80 if that's not out of his price range?
The 36t ring may be a bit large for his needs though!
FSA do a few- actually, if you don't mind used, I should have a set of white FSA Gravity Lights for sale shortly- wee bit heavier than XT but still sensible, and I'll not be looking for much.
Thanks guys,
I like the Zee's but restricting him to a single chainring might be a bit harsh!
@Northwind - when are you looking to shift your Gravity Lights..?
Depends slightly on when the new ones arrive tbh! Hopefulyl after the weekend. (I had to switch to 165s for a cramped frame, changed frame so going back to 175s)
Zee +1.
Cheap as proverbial chips, lightish and not noticeably less stiff than the saints they replaced, (snapped c/ring tab)..
Spa Cycles should be able to help.
Have a look on the website.
