160mm lyrik with mi...
[Closed] 160mm lyrik with mission control - how much oil?
in the damper? 193ml doesn't even fit!
Posted : 11/01/2013 10:38 pm
Is it a fork that spmeones done a damper upgrade on? My first thought would be what's the rebound damper- is the fork a solo air or similar with mico compression damper upgrade only? If the rebound damper is from one of the cheaper forks the quantity of oil is different due to the damper diameter- you can see this in the rs parts manual. Sorry don't know the correct amount.
Posted : 11/01/2013 10:51 pm
It varies per age, Google will tell you.
Posted : 11/01/2013 10:53 pm
126 ml
Posted : 11/01/2013 11:03 pm
Hob nob - do you not think i tried that first!!
Liftman - where did you get 126ml from? the sram video says 113ml but the seervice guides say up to 193ml ffs!
Vinneyh - the spring is inconsequential - the damper and rebound are stock from that fork
Posted : 11/01/2013 11:16 pm
sorted 112ml
Posted : 11/01/2013 11:19 pm
Posted : 11/01/2013 11:30 pm
how do i determine which rebound damper? seems to work with 112ml in. the mico unit won't fit in with any more oil so i will try that ๐Ÿ™‚
Posted : 11/01/2013 11:31 pm
Have you opened the valves in the rebound damper and mi-co damper by turning rebound to fast(jakalope) and compression to fast, floodgate full open, lock out pushed in?
Posted : 13/01/2013 7:11 am
Lockout removed, others open
Posted : 13/01/2013 11:48 am
u turn wound off?
Posted : 13/01/2013 11:50 am
Lowers off
Posted : 13/01/2013 1:47 pm
