15mm trhu axle endc...
15mm trhu axle endcaps
[#13535337]
Looking for the hive mind on this one.....
I have an Octane One wheelset which is missing a front endcap. The endcap is 15mm and the thru axle passes straight through a 6902 bearing hub using a thrust axle design. As a result the endcap contacts the bearing inner race.
Can anyone recommend to me a suitable substitute? Key dimension is 15mm ID, no recessed back, and a axial length of at least 13mm. The orginal OD at the hub interface is approx 28mm but I can turn down a suitable cap to fit these dimensions.
Any suggestions from mechanics?
Posted : 28/04/2026 8:44 pm
Check AliExpress for DT end caps, lots of the listings give measurements. The disc side of this one has dimensions that might work https://www.aliexpress.com/item/1005007822439862.html
Posted : 29/04/2026 9:56 am
