15mm QR on Reba RL ...
[Closed] 15mm QR on Reba RL 29 possible?
Dear All,
I am considering to buy the Cube Reaction GTC Race 29. The only bad point is the 9mm QR for a 29er.
Do you know if the fork can receive a 15mm maxle? It is not clear on sram website
(of course changing the wheels)
Thanks
Posted : 31/01/2013 11:58 pm
 nuke
If you want the forks to have 15mm Maxle, you'd have to replace the lowers which would be costly.
Posted : 01/02/2013 12:02 am
The drop outs are different so no - unless you change the fork lowers. About £250 for the replacement lowers.
so better to change the fork I guess?
Posted : 01/02/2013 12:05 am
 nuke
Yeah probably cheaper/simpler to sell off the forks on the bike before use and get a new set off Merlin or the like
Posted : 01/02/2013 12:06 am
strange, I read on Sram website: [i]9 mm QR or Maxle Lite 15 mm[/i]
Posted : 01/02/2013 12:07 am
and of course thanks for your help
Posted : 01/02/2013 12:12 am
 nuke
[i] I read on Sram website: 9 mm QR or Maxle Lite 15 mm[/i]
Exactly... 9 mm QR [b][u]or [/u][/b] Maxle Lite 15 mm. In the same way 1-1/8" [u][b]or [/b][/u] 1.5 to 1 1/8" Taper
Posted : 01/02/2013 12:14 am
and do you confirm that on a 29er, it is better to go for the 15mm?
changing pergaps the wheels, here "Sun Ringlé Radium wheelset"
Posted : 01/02/2013 12:19 am
The fork comes set up for 9mm alternatively it is available set up for 15mm. Their English could be clearer but....
Posted : 01/02/2013 12:20 am
yes, and MY english is very bad... 🙂
Posted : 01/02/2013 12:24 am
is it complicated (and expensive) to change to original 9 set up in 15 ?
Yes you'll need new forks(or fork lowers) and a 15mm front wheel. Is the next bike up not equipped with a 15mm fork?
Jay
Posted : 01/02/2013 3:57 am
yes, indeed, SID RL 29 and 15mm QR but 400 pounds more (540 eur)
Posted : 01/02/2013 8:52 am
Fundamental question - why do you think you need 15mm?
I have two bikes, one with qr and one with 15mm both are reba forks. I am hard pressed to tell the difference 90% of the time.
Suggestion - stick with 9mm qrs.
Posted : 01/02/2013 9:25 am
just because even in the dealer, it was told that a 29er with 9mm is a lack of rigidity.
He told me that it is not a problem on 26er.
That's why I ask this question to specialists as you, I am novice on this technical things.
What I would like to avoid is to by the Race, then in a few months, buy new rims, and so spend the same money as the difference of the two bikes today...
Thanks for your time
Posted : 01/02/2013 10:36 am
Hi, I have a 26er with 15mm bolt thru, & a 29er with 9 mm qr (same forks as you mention above).
At first I was a bit concerned the 9mm qr may not be up to it but after a few months & a few offs I really can't see any difference.
Now I don't even think about it.
Posted : 01/02/2013 10:50 am
So even if I change rims later, keeping 9mm is an option?
Posted : 01/02/2013 11:04 am
