Which is best compromise between uphill stability and downhill bump eating? For use with BFe for general duties, not freeride / downhills. AND is there a difference in crown / axle heights between RS and Fox for equiv travels? eg would a 150 Fox have same eventual frame angles as a 150 mm RS
ta
I've had a few forks on my BFe now. 160mm was fun downhill but could be a problem on steep climbs sometimes. 150 not bad (and what's fitted currently) but 140mm was probably the best for general riding.
I've got a set of coil Pikes on my Soul but I reckon they'll eventually find themselves on the BFe and the Soul will go back to a 120mm air fork.
Cheers epicsteve and that`s very helpful info; glad someone else goes through a range of forks too ; have used Pace RC40 100-130 coils , OK, RS Revs dual position 150/120, lovely forks on small bumps, etc BUT appears to be big issue with forks settling into an excessive sag position after downhills (eg 40% sag) and not rcovering unless unweighted ๐ ๐ , 2nd set now and same issue>> back to RS for refund hence looking for something else
