135mm rear dropout ...
[Closed] 135mm rear dropout with 130mm wheel. Will I die etc...?
Hybrid bike, aluminium frame with 135mm rear dropout. Can I safely fit a 130mm road wheel or is it a bonkers plan? Thanks for any help.
Posted : 10/03/2015 7:44 pm
Just look at 5mm on a ruler. Now divide that by 2 and think of the angle that's going to pull your nice long chainstays in by. It'll be absolutely fine.
Posted : 10/03/2015 7:52 pm
Posted : 10/03/2015 8:30 pm
As above. Been riding a set up like that for almost a decade without issues.
Posted : 10/03/2015 8:32 pm
Thanks for the replies. Do I need to add washers or anything or is it OK just to fit as it is?
Posted : 10/03/2015 9:09 pm
Is it temporary or permanent?
Perm I would (and have) fit a 135 axle. Temp wouldn't bother.
Posted : 10/03/2015 9:56 pm
My VN Amazon has a 132.5 mm rear end so it works just fine with either axle length. I don't think another 2.5mm is going to make much difference, other than when you're inserting the wheel and making sure everything is lined up.
Posted : 10/03/2015 10:08 pm
Permanent. Will look at possibility of changing the axle too. Ta.
Posted : 10/03/2015 10:20 pm
Washers would be bad as they would mean less axle in the dropout.
Just fit as is like the above.
Posted : 10/03/2015 10:43 pm
I disagree slightly. I found that the dropouts pull in unevenly (i.e. mostly from one side) which meant that the wheel had to be re-dished. As it was a shimano hub in the end I just replaced the axle with a 135mm one and added an extra spacer on the NDS.
Posted : 12/03/2015 11:11 am
