Brakes- XTR M975
[Closed] Brakes- XTR M975
[#6923626]
Hi all,
Got a set of XTR M975 brakes on my MTB, the front lever has started to weep brake fluid and there is no seal kit available, its not the reservoir cap.
If I bought a XTR M9020 trail lever ( http://www.chainreactioncycles.com/shimano-xtr-m9020-trail-disc-brake-lever/rp-prod119766 ) would it be compatible (or will I die)
Any other ideas as I love the M975 brakes but not available on ebay at a reasonable price and the XTR lever is only just over £50 ?
Thanks
Posted : 10/03/2015 7:57 pm
Any other shimano lever with the parallel reservoir should work. I have XT calipers running on Saint levers, XT calipers on SLX levers and LX on Saint levers. Although I will say that all of those combos feel better than the m975s I used to have on the Blender
Posted : 10/03/2015 8:22 pm
You can run new levers with old callipers if you use SMBH90 hoses with the narrower internal diameter.
Posted : 10/03/2015 9:48 pm
Cheers will buy some SMBH90 hoses and a lever and see what happens
Posted : 11/03/2015 8:42 am
