135 x 9mm to 135 x ...
[Closed] 135 x 9mm to 135 x 12mm hope hub
Is it possible? If so what do i need?
Posted : 24/01/2013 11:49 am
Beware the 12 x 135mm Hope unless it's an EVO hub... they break regularly as there is not a lot of aluminium left.
Posted : 24/01/2013 12:04 pm
Its and evo
Posted : 24/01/2013 12:45 pm
New frame 135x12, or just want a stiffer rear end (oo-errrr!) ?
You'll need a 135x12 axle for you hub - bearings remain the same.
If it's the same frame (QR), the Azonic Momentum axle is very handy.
Posted : 24/01/2013 12:50 pm
Bobbins. Old-style Pro 2 here, two years abuse and counting.
Posted : 24/01/2013 12:51 pm
Its and evo
If that means "It's an EVO Hub" then all you need are two end caps which are about £12.
[img] ?width=800[/img]
Posted : 24/01/2013 12:53 pm
Running 3 bikes with 135x12 here (Bulb, old Pro2, evo Pro2), and had zero issues with them.
Posted : 24/01/2013 12:54 pm
[url= http://singletrackworld.com/forum/topic/12mm-maxles-and-hope-pro2-hubs ]Thread from last year about broken Hope Pro2 12mm hub axles.[/url]
I've not broken an axle for over a year now running the EVO hubs.
Posted : 24/01/2013 1:03 pm
Well i've broken 2 9mm hope axles, so not just related to 12mm, this was after 1000's of miles though
12mm as a frame I'm looking at has that and i want to use my existing hub
Posted : 24/01/2013 2:49 pm
If you have or know someone with a lathe, just bore out the 10mm QR end caps to 12mm, Simples 😉
Posted : 24/01/2013 3:02 pm
