130mm 29er Forks ? ...
[Closed] 130mm 29er Forks ? Options.
10 Users
Just wondering what 29er forks are available in 130mm travel.
I know pikes can be lowered etc so is that the same for revelation and sektor models.
Thanks.
Posted : 25/03/2017 11:21 am
Depends what offset you want 😉
Posted : 25/03/2017 11:39 am
Oh yes. 46mm please.
Posted : 25/03/2017 11:43 am
Pikes (or Yari) for me, actually that what I have on my main bike 😀
For a person of a larger nature (fat lads like us 😀 ), I wouldn't rush to buy anything under a 34mm stanchion
Posted : 25/03/2017 11:53 am
 br
Pikes. End of thread.
Posted : 25/03/2017 11:55 am
Are any of the x Fusion forks 34mm
Posted : 25/03/2017 12:04 pm
 mboy
MRP Stage...
But then you knew that already! 😉
Posted : 25/03/2017 12:24 pm
X-Fusion slant is 34mm, I was interested but IIRC they only go up/down travel wise in 20mm jumps.
Posted : 25/03/2017 12:35 pm
Don't tempt me mboy !!!
Posted : 25/03/2017 2:54 pm
Trace
Posted : 25/03/2017 3:17 pm
Fox 34 fit4 come in 130mm that's what mine are.
X fusion new MacQueen fork can come in 130mm travel can take 29er wheels
Posted : 25/03/2017 3:56 pm
MRP stage (again)
Posted : 25/03/2017 6:42 pm
I recently fitted a pair of 130mm RS Pikes on my full-suss 29er, they're far superior to the 120mm Fox Factory 32's they replaced.
Posted : 26/03/2017 6:40 am
If you use the internal roll pin then that is true but you can use 10mm (or less if you trim them) spacers to get smaller travel changes.
I've got a 140mm travel Trace that's dropped to 120mm but could do 130mm if a spacer is used. It's a 34mm chassis fork
Posted : 26/03/2017 9:14 am
Wasn't aware of that, thought it was a pin only travel change option, & I was incorrect the 34mm stanchion x-fusion 29er model is the trace. The slant is/was the 26er version
Posted : 26/03/2017 9:23 am
You can use a combo of the pin and the spacers to get where you want
Posted : 26/03/2017 9:25 am
