125 Motorbike headl...
[Closed] 125 Motorbike headlights...
[#4569131]
Posted : 18/11/2012 7:34 pm
They are a joke on the bigger bikes too lol I've done a mod on mine that bypasses the wiring loom and goes direct from battery to lights via a switch and an auto relay its much brighter now as for your question not sure but I'll bet your not allowed 🙁
Posted : 18/11/2012 7:45 pm
Can't see why not.
Posted : 18/11/2012 7:47 pm
Can't see the question.
That seems like quite a lot, don't most bikes have just 1 or 2? 😉
Posted : 18/11/2012 7:55 pm
smart phone delete post fail!
Question was basically why are 125 cc bike headlights total pants and could I use a couple of cree spotlights screwed on the side of my fairing/forks whatever for unlit road riding
you can buy running lights for motorbikes but they drain battery and 125's don't have that much extra power
Posted : 18/11/2012 9:54 pm
First step is to check bulb and if possible upgrade to halogen
Posted : 18/11/2012 11:52 pm
Posted : 19/11/2012 12:01 am
I'd check the legalities of fitting what would effectively be spot lamps at headlamp height. Check out the construction and use regulations. In my day, most 125cc bikes had 6 Volt electrics. That would reduce your options for replacement bulbs.
Posted : 19/11/2012 12:02 am
Lots of bikes have crap headlights unfortunately. You could bodge on extra lights but will not be road legal unless e-marked.
First thing to do is probably to upgrade the bulb to the best you can find for your fitment- think Osram Nightbreakers are probably still competitive but there might be better now.
There's other options though... I used a (illegal) HID light conversion in my bike for ages. Definately a "ymmv" thing though- my bike had twin headlights and one side couldn't be convinced to aim safely, so I removed the HID from that and went back to a Nightbreaker in that side. The other aimed well and was safe- passed 2 MOTs (though legally shouldn't) and also various police inspections.
But equally you could spend a lot of money and just get something that works badly or even unsafely, so.
Lastly depending on your bike it might be practical to replace the whole unit with something better- if it's an unfaired bike, that'd probably be straightforward assuming a 12V system.
Posted : 19/11/2012 12:51 am
You can also use a helmet light. Run it off bike supply and wire so it only comes on with main beam
Posted : 19/11/2012 9:04 am
