120mm travel full s...
[Closed] 120mm travel full sus with slack head angle suggestions
I am wanting to get back into going for long distance rides and though I love my Geometron after 8 hours of riding with its 160mm of travel and rugged components leaves me wanting something a bit lighter.
So I looking for a lightish short travel bike with slackish head angle Im not sure what's out there. So Looking for ideas of what's out there for a full suspension that has a slacker head angle than 67 degrees with a reach greater 500mm.
Posted : 21/03/2019 2:47 pm
Works Angleset may have to be part of the answer.
Posted : 21/03/2019 2:51 pm
Whyte S120 looks good, providing you like 29ers.
Bird Aeris 120
Posted : 21/03/2019 3:03 pm
Not fashionably niche, but new Stumpy comp?
Posted : 21/03/2019 3:06 pm
 wors
Bird Aeris 120, Whyte s120, Merida 120, Giant Trance 29er
Posted : 21/03/2019 3:10 pm
 Yak
The Saturn 11 is the xc/marathon version if you want to keep it all in brand. 120mm/105mm front/rear so a bit less than you are after. Just slightly steeper than 67deg and the reach is over 500mm in the biggest size.
Posted : 21/03/2019 3:13 pm
Not sure on your budget but in true STW tradition I'll suggest what I've got and say evil following. Pedals brilliantly, descends much better than I do and builds up to a very respectable weight.
It is a smidgen over 67 degrees with a 130 fork but it's a great ride.
Stumpy evo st is 67.5 and by all accounts its a hoot.
Edit, just reread and noticed 500mm reach. That's a loooong reach on a short travel bike. What size are you looking for, I'm guessing XL at that?
Posted : 21/03/2019 3:21 pm
Transition smuggler (140/120), bit more in the front but won’t feel it in a bad way? Whyte 120 definitely worth a look.
Posted : 21/03/2019 3:23 pm
 wors
Cotic Flaremax too
Posted : 21/03/2019 3:31 pm
I am sort of tempted in the same way. But I have relatively large (2.5/2.4 width) and chunky tread tyres on my 160mm Transition. So I could lose some rolling resistance there.
I often use a long travel, steel hard tail for local stuff, which makes me hark back to a softer rear end.
I think the Whyte range is always worth a look for 120mm bikes.
Posted : 21/03/2019 3:41 pm
I love my FlareMax for all day rides, but it doesn't fit the OP's requiremens of "light". I had a Trance back in 2012, which was light for an alloy bike and a very good XC/Trail bike. Assimung that hasn't changed I'd be giving the new Trance 29er a look. Especially in bright green 🙂
Posted : 21/03/2019 3:43 pm
Hi
Thanks for all the replays. Completely forgot about bird and Whyte.
Yes looking xl or xxl as I am 6'5ish.
Should have mentioned budget in the range of £2.5k to £3.5k which quite a few above will fit into.
Going to see if I can demo the Whyte
Posted : 21/03/2019 3:55 pm
Scott Spark is around 67 degrees but feels slacker but the reach is only 477mm. That said, when I first rode one I thought the cockpit was too short but stopped even noticing it after a couple of minutes.
Posted : 21/03/2019 4:49 pm
Pole Evolink?
Posted : 21/03/2019 4:52 pm
 Alex
I was going to say Bird Aeris 120... /stealth ad, I have one for sale 🙂 EDIT: Not one that size, as you were!
I was runing mine with a 140mm fork tho. Still felt lively.
Posted : 21/03/2019 5:15 pm
 a11y
Santa Cruz Tallboy in XXL with a 130-140 fork.
SC Tallboy in XXL with a 130-140 fork. I’m 6’1ish on an XL and don’t find mine overly short, not even next to the NP Mega 290 I recently sold which had 515mm reach.
Seen some bargain Tallboys within budget but unfortunately slim chance of finding a XXL I guess.
Posted : 21/03/2019 5:16 pm
Evil Following
Posted : 21/03/2019 7:40 pm
Orange segment meet the criteria, start fitness have up to a grand off.
Think drake cycles still have a factory version with 2k off.
Posted : 21/03/2019 7:55 pm
Going to keep my eye on the thread, as I wouldn’t mind a lightish short travel 29er to replace my Spesh Camber Evo that’s a bit small for me.  New Whyte looks interesting, but I wonder if Giant will be doing an AnthemX 29 sometime(?)
Suggestion wise, how about an Orange Stage 4?
Posted : 21/03/2019 8:33 pm
Intense Sniper Trail.
Posted : 21/03/2019 8:36 pm
What Geometron do you have? A G13 is everything you're looking for surely?
Posted : 21/03/2019 10:36 pm
Mojo g16 running hybrid.
Posted : 21/03/2019 11:05 pm
