120mm trail fork, a...
[Closed] 120mm trail fork, air sprung or coil?
Thinking of replacing a Manitou Black super air that must date from about 2004. Got an air spring, but because I'm a bigger rider I end up running it with such a high pressure that it doesn't really have any small bump movement, yet it can still run through travel quite easily.
I was wondering about some of the coil sprung Rock Shok with a firm spring upgrade, would a coil spring give a better ride than an air spring?
Posted : 11/10/2010 4:26 pm
Similar issues here, switched to a pike with X-firm spring, problem solved
Posted : 11/10/2010 4:30 pm
coil springs ALWAYS give a better ride, if the fork is tuned properly. BUT, air sprung forks nowadays are pretty close.
Coil = small weight penalty, small performance increase, better reliability.
Air = small weight gain, small performance drop, worse reliability.
If you don't really care about weight too much, get a coil, and get a good one.
Of course, it's all IMHO, and apparently round here you should have no gears, no suspension, and a beard.
Posted : 11/10/2010 4:31 pm
By the way, I've tried them all (almost) and I weigh in at the bantam weight of 18 stone.
Posted : 11/10/2010 4:32 pm
Thanks for the input guys, that what a mate was telling me.
Weight isn't an issue, more to lose off me before I get worried about how much I take off the bike, I just need to improve the ride first!
Posted : 11/10/2010 4:36 pm
Being of rotund stature, & having recently gone from a X-Firm sprung Pike to an air sprung maxle Rev, I'd say...air. Pike nice & supple, but add in a 20mm axle & its quite heavy. Air sprung Maxle Rev is simply excellent.
Get a proper spring sourced from someone like TF Tuned, as it will make all the difference. Or better still get a cheaper fork and spend the extra getting it valved/tuned for your weight and riding style.
Posted : 11/10/2010 4:38 pm
