12 speed xt shifter...
12 speed xt shifter, wouldn't get gears, fixed with a clean..
But is that likely to be a permanent fix?
Bought a second hand bike with xt gears. Great I thought.
The mech lost tension, less great. Cured with a load of wd40 and working it back and forwards. Fine
Today the shifter would only get 4 then 6 then 7 then 4 gears. Even less great.
Couldn't find any shops open today to buy a replacement closure than an hour's drive, so took the shifter to bits and cleaned it up.
It now gets all the gears.
Is this likely to be a permanent fix?
While fixing this the rear mech lost tension again so I've fitted the deore mech I bought when the xt one. Making me wonder if I should buy a new shifter to go with the new rear mech
Looks like the bike was more used than I thought 🙂
Posted : 27/07/2025 3:47 pm
WD40 isn’t a lube. It will shift some grime but leave everything dry.
Use some proper grease on the internals and spray lube on the cable inners.
Posted : 27/07/2025 4:00 pm
tall_martin reacted
You probably needed to pull apart the clutch mechanism and de-gunk/regrease the axle directly behind it. But I've always found the writing was on the wall for the mech at that point, although you might get a few more months out of it. Likewise the shifter once it starts misbehaving.
Posted : 27/07/2025 4:13 pm
tall_martin reacted
Which bits of the shifter need greasing?
Everything that moves?
The mech will get cleaned and rebuilt and used as a spare.
Posted : 27/07/2025 4:41 pm
If your mech lost tension, I'd suggest the roller bearing is borked.
A clutch service won't fix that, you'll need to replace the bearing.
Posted : 27/07/2025 4:59 pm
tall_martin reacted
Which part is the roller bearing?
I'm talking about the p-axle (10), I found that tends to get gunked up or even corroded on these mechs and reduce return speed enough to produce a slack chain. Obviously you need to take apart the clutch assembly to get at it.
Posted : 27/07/2025 5:33 pm
That exploded diagram will be very helpful if/ when the rebuild explodes into 50 tiny pieces 😱
Posted : 27/07/2025 8:38 pm
You can see it inside the circular stabilizer unit.
My experience was the bearings rusted and seized to the p-axle.
I replaced one from a broken saint mech. The other shimano sent me the parts.
Posted : 27/07/2025 9:39 pm
