11speed compatible ...
[Closed] 11speed compatible road disc hubs?
4 Users
Anyone know if its possible to put an 11speed freehub on a DT Swiss 350/240 mtb hub or does it mess up the spacing?
Alternative reliable hub suggestions would also be welcome, my current Novatec 772 is very good at destroying berings quickly.
Posted : 18/12/2014 11:25 am
Should be reet.
Posted : 18/12/2014 11:27 am
Superb, cheers 🙂
Posted : 18/12/2014 11:31 am
It makes it 1.1mm (iirc) wider so theoretically the dish will be out by 0.55mm.
You will almost certainly die in flames (or you could put 1/8th turn on the driveside spokes).
Posted : 18/12/2014 12:12 pm
I'd not even bother with that.
Posted : 18/12/2014 12:17 pm
Yep, I just swapped the free hub body over on my 240's
Posted : 18/12/2014 12:40 pm
