11s cassette on 10s...
[Closed] 11s cassette on 10s hub
Can't be done, right? 11s cassette is about 1.8mm wider than a 10s freehub. Previously I'd just taken out one sprocket (14t) and use the 11s groupset in 10s mode, but with a 32t cassette that would leave a bit too much of a gap.
I've just shaved off about 1.8mm from the alu carrier of a 105 11-32 5800 cassette. Took about 5 mins and means those good but outdated 10s wheels are no longer obsolete 😀
Happy to do this for others if anyone's interested - obviously with no liability if it bursts into flames/makes you crash/destroys your bike...
Posted : 29/06/2018 7:01 pm
ooh yes pls
Posted : 29/06/2018 7:10 pm
This is road yeah? Pretty sure I have an 11spd mtb cassette on 10spd hub.
Posted : 29/06/2018 7:15 pm
Yeah was going to ask if this was a road thing,bloody idiots the lot of them
Posted : 29/06/2018 7:16 pm
 P20
I thought the latest 11spd 105 has been made to fit the 10spd hub?
Posted : 29/06/2018 7:24 pm
Yeah, it's all road stuff, though older MTB freehubs are also narrower than newer ones (this is going on a Hope XC hub). I've no idea about 11s MTB stuff I'm afraid.
Posted : 29/06/2018 7:36 pm
MTB 8,9,10 and Shimano 11 spd all fit on the same freehub width.
Posted : 29/06/2018 8:01 pm
 P20
Found it!
Forgot to add before, impressive work in the first place!
I’m planning on fitting 11sp 105 to my 10sp freehub over the weekend. After a bit of reading I was expecting to just have to remove the 11T and run it as 10sp? I never use the 11T anyway
Posted : 29/06/2018 8:53 pm
P20 - yup, both the new 105 and Ultegra 11-34 11 speed cassettes fit 10spd Road freehubs. Tighter spreads only fit 11 spd freehubs as they would otherwise risk chain/spoke interference.
Mowgli - guessing 32T should be OK on most hubs re spoke clearance, but any guesstimate at what size it might become an issue?
Posted : 29/06/2018 9:47 pm
In the long run it's easier to take that 1.8mm off the freehub. Done that to several Hope XC hubs and also numerous Shimano ones. Quicker to use a files than set a lathe up and fiddle with it bouncing around.
Posted : 29/06/2018 11:37 pm
I don't know, it was literally five minutes from sticking it in the chuck to deburring the edges. I guess I did have the right tool mounted already. I'd rather machine a soft alu cassette which is essentially a consumble rather than trying to mangle my nice Ti freehub with a file.
<span style="font-size: 0.8rem;"> Seems odd that they've almost backtracked by making the newer 11s 105 and Ultegra cassettes narrower again now. </span>
I wouldn't like to guess on minimum tooth count for this to work - I don't have any others to hand to check. There's plenty of clearance on the 32.
Posted : 29/06/2018 11:52 pm
This fella did the same thing a while back:
Posted : 30/06/2018 2:42 am
For the record, i fitted an 11sp 105 cassette on to my 10sp free hub today, no issues at all. Pleasantly surprised
Posted : 03/07/2018 12:54 am
Interesting. What type of 105, and which hub?
Posted : 03/07/2018 8:08 am
With my limited knowledge, it’s the standard 9/10sp freehub that came on my mk2 Escapade, and the 105 5800 32-11 cassette that came on my 2015 Giant Defy. There was a small spacer behind the 9sp Sora 32-11 cassette which I obviously removed
Posted : 03/07/2018 8:38 pm
