11 Speed MTB Casset...
[Closed] 11 Speed MTB Cassette On 130mm Road Hub
Going to restore an old steel frame I have for some casual riding and the odd commute and kit out with modern components where possible. ย Rear end uses a 130mm hub so I'm thinking of building up a set of wheels using DT350 road hubs using a Shimano body. I think I'm correct in thinking this should take an 11 speed MTB cassette with a spacer being 11 speed Road cassette compatible and I can run a standard 11 speed MTB shifter, etc. Can someone confirm this is correct unless in case I'm having a n00b moment.
Posted : 13/02/2018 10:23 pm
you are correct
Posted : 13/02/2018 11:22 pm
