10sp shimano clutch...
[Closed] 10sp shimano clutch mech with 9sp SRAM shifter
Anyone know where I can get a spacer made, or can give me an idea how to make it work properly?
Posted : 20/05/2013 10:43 am
Im going to use a square nut, file/sand it down to 7mm, then cut a 1mm groove for the cable. Also drill out the threads.
Posted : 20/05/2013 10:55 am
I made my own... I used my mill because it'd be daft not to but you could do it with hand tools, all it really is, is a cuboid with a hole and a slot.
Or you can just use a stack of washers, but that's a wee bit fiddly.
Posted : 20/05/2013 12:47 pm
yeah, get a 10 speed shimano shifter.
Posted : 20/05/2013 12:59 pm
That would make it worse? Were talking of making a 9 speed system work with a clutched mech.
Posted : 20/05/2013 1:31 pm
At the point when I can get the 10sp cassette, shifter and chain then ill do that but I'm trying to take it easy on cash right now. I have a 9sp SRAM shifter already - if I get one of the new works components / wolf tooth chain rings then I can take a step toward 1x10 without having to get a chain device (I've never seen one I liked) and the idea of a clutch mech / bash guard and 'proper' chainring sounds good
The 7mm square nut and a 1mm channel sounds right. Cheers Rob!!
Posted : 20/05/2013 2:01 pm
