10mm thru axle - em...
[Closed] 10mm thru axle - emplain for me please?
[#1028889]
Am looking at getting some new wheels. Anyway not being of the downhill persuasion i don't know much about upgraded axle standards. So one of the options i've been looking it is a set of DTswiss wheels with a possible 10mm rear thru axle. Is this a downhill freeride only specific standard? & will they work with a frame that doesn't have 10mm specific dropouts? e.g. my chameleon
Posted : 10/11/2009 7:09 pm
its a 10mm straight through axle, probably fixed with a bolt or maybe an RWS if its DT.
as long as its 135mm spacing then it should fit in your chameleon.
Posted : 10/11/2009 7:13 pm
10mm is the standard diameter for rear axles.
Posted : 10/11/2009 8:44 pm
yes it will fit in your dropout as they are 10mm as said above
Posted : 10/11/2009 8:53 pm
 DeeW
DT RWS 10mm axles work in just about any standard 135mm QR compatible frames. Should provide a bit of extra stiffness.
I've got a used one for sale if you're interested..
Dave
Posted : 10/11/2009 10:24 pm
 igm
Hadley
Posted : 10/11/2009 11:07 pm
