I've been using a set of 100mm Marzocchi MXC air forks on my cheap and cheerful Kona hardtail for a few years.
I use 10wt oil and I have raised the oil levels to just about as far as I can to provide some ramping-up/bottom-out resistance whilst retaining some plushness.
They have been excellent forks and have withstood some fairly hard riding.
I was wondering what other (cheap-ish, used) lightweight forks with 100/110mm might be 'better'.
Suggestions?
New of 2nd hand?
Anything (new) Rockshox would be my choice.. Tora's (cheap & not the lightest), Recon's (mid priced), Reba's (more expensive & lightish) but all can be had for less than £200 2nd hand..
I'm thinking used.
I have a set of Pike coils on my full suss and like them. They're not light though.
Reba's or Revelation's then (rev's wound down) both are a lot lighter than 2.5Kg coil Pikes... lot of different choice axle wise, and older Rev's used to have a coil option IIRC if you like that option.
In this case I'm looking for air forks for my light-ish hardtail.
Any more for any more?
I just ordered [url= http://www.on-one.co.uk/i/q/FORSRERL/rockshox_reba_rl_dual_air_100mm_fork_with_poplock__26_inch ]these[/url] Rebas - at £230 seem a good buy.
Another one for Rebas here. The teams are better, but noticeably platformier. The OEM Recons come with a 10mm travel spacer which you should be able to find if you wanted 110mm out of them, otherwise they're good at 120, but a little bit flexier. I should have a spare 10mm kicking around if you need one.
