10 speed shifter / ...
[Closed] 10 speed shifter / 9 speed mech / 8 speed cassette
Hi all,
Quick one fora friend - will this work, all Shimano MTB:
Thanks,
Duane.
Posted : 29/01/2019 11:53 am
no the spacing on a 8 speed cassette is very wide in comparision to modern standards.
In fact im not sure any of it will work together,
Posted : 29/01/2019 11:56 am
No
No, cable pull on 10 speed shifter is different.
An 8 speed shifter will work with an 9 speed mech though.
Posted : 29/01/2019 11:57 am
OK thanks. What mech and shifter combos will work with 8 speed cassette - does mech and shifter have to be 8 sp too?
What defines the pull ratio - the mech or the shifter?
Posted : 29/01/2019 11:59 am
Shifter defines the pull ratio, mech is designed to work with the pull ratio.
Shimano changed the pull ratio for 10 speed so 8 or 9 speed mech should work with an 8 speed shimano shifter (I used to run 9 speed XT mechs with a XT 8 speed shifter).
Posted : 29/01/2019 12:04 pm
The shifter has to be 8 speed. The mech can be 7/8/9 speed.
Posted : 29/01/2019 12:08 pm
As above, 8 and 9 speed deraillers are interchangable. The spacing on 8 and 9 speed is different, so you cannot use 9 speed shifters with an 8 speed cassette.
Posted : 29/01/2019 12:45 pm
OK thanks a lot everything, he has ordered an 8 speed mech and shifter for simplicity ๐Ÿ™‚
Posted : 29/01/2019 3:15 pm
