10 Speed question
[Closed] 10 Speed question
The width of a 10 speed cassette is the same as a 9 speed. So, would a 9 speed XT rear mech work with a 10 speed shifter and cassette?
Posted : 01/01/2011 12:50 pm
No.
Different rate of pull (or summink) - it's been covered a lot here if you search it.
[url= http://www.singletrackworld.com/forum/topic/10-speed-derailleur-9-speed-cassette-shifter ]Here you go[/url]
I really don't get why so many people are struggling with this. Everyone gets that you can't mix SRAM/Shimano mechs, this is exactly the same. There are now 4 cable pull ratios:
- Shimano 9 speed and 10 speed road excluding Dura Ace 7900, Ultegra 6700 and 105 5700
- Shimano 10 speed MTB and road groupsets as above
- SRAM 9 speed
- SRAM 10 speed road and MTB
Rear mech and shifter must match, there will inevitably be bodges to get it half working, but basically avoid mixing and matching!
Posted : 01/01/2011 12:55 pm
sorry for the hijack, but on a simular note has anyone ran a road 10 speed chain with the XT setup as I need to replace my 10 speed XT chain and was looking for a cheaper alternative.
PS i'm aware that the inner plate are thinner on the MTB chains.
Posted : 01/01/2011 1:14 pm
Cheers, although I still don't get it, the mech moves in accordance to the shifter, it's the shifter that determines the rate of pull surely! Also a 10 speed mech apparently works fine with 9 a speed shifter and cassette so why would it not work the other way???
Posted : 01/01/2011 1:15 pm
i was told its to do with the rear mech linkage and that its slight different to the 9 speed mech , hence different pull ratio.
but try it and report back.
Posted : 01/01/2011 1:17 pm
The cable pulls around a curve/cam on the rear mech. The curve is different.
Or something.
Can you go 9 spd front shifter and mech, with 10 spd rear and chainset?
Posted : 01/01/2011 1:23 pm
