Tec M4 & Shifte...
[Closed] Tec M4 & Shifter
[#2328087]
Happy New year all, just fitting my new M4s and a little dissapointed with the way the flip flop leaver obstructs the shifter return lever (fore finger lever) Anyone had this happen to them and anyone know if there is a combined shifter/brake bracket. Standard shimano XT shifter by the way.
Thanks
Posted : 01/01/2011 1:29 pm
Move the lever inboard. Unless you have weird hands - I beg your pardon if you do - you'll probably find that the brake feels much better anyway, if your braking finger is closer to the tip of the lever blade.
Posted : 01/01/2011 1:41 pm
Yes Hope make a XT matchmaker clamp one clamp then for brake & shifter. Might need to check if your XT shifter is compatable.
http://www.cyclesportsuk.co.uk/product_info.php?products_id=9244
Hope that helps
Posted : 01/01/2011 1:42 pm
I have SRAM shifters rather than XT, but there are two things about the Tech levers which should be common:
1) The actual levers are pretty long, so you need to mount them a long way inboard for one finger braking. Should leave plenty of room for the shifter
2) I use the matchmaker clamp which is absolutely brilliant. Plenty of adjustment for perfect positioning and less clutter on the bars
Posted : 01/01/2011 1:51 pm
XT shifters also have an adjustable mount so you can move them left and right once you've settled on a brake position.
Posted : 01/01/2011 2:49 pm
Thanks for your comment...yeh can move the lever inboard a little but its a personal set up thinking I will look into the combo.
Thanks
Posted : 01/01/2011 3:49 pm
How many fingers do you use to brake?
Posted : 01/01/2011 3:50 pm
