10 speed, chain opt...
[Closed] 10 speed, chain options
bugger,
as i understand it sram 10 speed chains now cannot be taken apart once they have been joined by their new power link.
this is bad news as i often take my chain apart for cleaning.
anyone know of any other 10 speed chains that use a "power link" type thing to easily break them apart.
really starting to regret going for a 10 speed set up!
Posted : 21/08/2011 10:11 pm
Use a KMC quick link in the chain - they're re-usable
Posted : 21/08/2011 10:12 pm
Got a KMC chain, been good for the 3 months I've had it so far.
Posted : 21/08/2011 10:20 pm
sambob ,which KMC chain you got?
Posted : 21/08/2011 10:22 pm
I've got one of these:
http://www.kmcchain.com/index.php?ln=en&fn=find&mo=view&id=600
Not cheap, but claimed to be long lasting & the link is easy to undo. Has been fine although using detergent on it is a no-no they say.
Posted : 21/08/2011 10:27 pm
Just saw this, thought I'd pop off and get a few 10sp KMC links to keep in the bag for emergencies.
http://www.chainreactioncycles.com/Models.aspx?ModelID=25439
Nine quid each? Seriously?
Posted : 21/08/2011 10:41 pm
I think you get two sets for that price, which makes it not bad
Posted : 21/08/2011 10:46 pm
They lie. X10SLs are light, but longevity is poor IMO!
PowerLocks are about £5 each and single use, the KMC ones are better value!
Posted : 22/08/2011 7:24 am
Got an SRAM 10 speed with their own power link and have been taking it apart using a park tools power link splitter tool then reusing the same power link when reassembling the chain. Done it a few times now and seems to work fine.
Posted : 22/08/2011 8:38 am
If your using a tool to take the chain apart then isn't that missing the point. I want a 10 speed chain I can take apart easily for cleaning
Posted : 22/08/2011 8:51 am
And although it do[i]es come apart it's not designed to. Power Links are already the weakest part of the chain, I'm not about to start making them do something they're not designed to!
Posted : 22/08/2011 9:11 am
njee20 - I've been using 8/9 speed SRAM powerlinks for years and taking the chain off cleaning once a month or so without any issues. Are 10 speed that narrow and therefore that finnicky that you cant take them apart using a powerlink etc? Therefore 10spd is not useable for day to day mtb'ing.
Posted : 22/08/2011 9:15 am
I've been using a 10 speed Shimano HG74 with a KMC 'Missing Link' for a while now and it's been faultless, great sifting and no sign of wear
Wouldn't have normally touched a Shimano chain given failures some years ago but I needed 116 links and that's all I could find, turned out OK though
Posted : 22/08/2011 9:20 am
 tang
Wipperman connex, great chain and comes with the link.
Posted : 22/08/2011 9:25 am
No, but the 10 speed ones aren't Power[b]Links[/b], they're Power[b]Locks[/b], they're not designed to come apart, they are single use. Forcing them apart using tools isn't all that sensible when KMC and Connex make reusable links IMO.
I've been using 10 speed for 2 years now, chain longevity is no different to 9 speed IME.
Posted : 22/08/2011 9:26 am
Sorry, i've got no idea. Was £30 i think though, if that helps.
Posted : 22/08/2011 10:11 am
It is easy, the tool is a bit like a set of pliers that you use to split the power lock. They come apart as easily as the old 9 speed ones. I do it to clean the chain then reuse the same power lock when putting it back together. Been doing this for a few months and not had any problems.
Edit: [url= http://www.parktool.com/product/master-link-pliers-mlp-1 ]Park tools master link pliers[/url] - cheaper ones are available in other colours!
Posted : 22/08/2011 10:21 am
But you're only ever gonna have one problem, and it'll likely lead to a testicle/stem interface or worse. I'll continue to use one that's designed to be reused 🙂
Posted : 22/08/2011 10:23 am
I suspect it would be sensible to change the power lock link every few splits 😐
Posted : 22/08/2011 10:27 am
what happens when i 10 speed chain snaps? can you not just put it back together with a chain tool, like other chains?
Posted : 22/08/2011 10:41 am
Or just use a reusable one 🙂
Yes, you can.
Posted : 22/08/2011 10:43 am
not sure the connex whipperman comes in a 10 speed with a "power link" type thingy
Posted : 22/08/2011 10:46 am
Geez I'm getting more confused now... but from whats being said, I need to get one of these, a KMC Missing Link.
http://www.kmcchain.eu/?en/products/connectors/missing_links/
I think the gold one would be best, spent ages in the past looking for SRAM's link on the chain..
Cant think why you would want to use a non reusable one?
Posted : 22/08/2011 10:49 am
That's what I use without issue
Posted : 22/08/2011 10:51 am
Just picked up two on EBay for 10 dollars. Plenty of Hong Kong/Taiwan sellers doing them for cheap.
Posted : 22/08/2011 11:18 am
Must admit I've never seen a choice in the UK - Chicken's only do silver ones.
They're pretty distinctive though, shouldn't take more than 30 seconds to look at the chain!
Posted : 22/08/2011 11:29 am
Pick whichever one suits your chain
http://www.highonbikes.com/catalogsearch/result/?q=missing+link&x=0&y=0
Posted : 22/08/2011 11:33 am
 tang
my wipperman connex from crc came with link.
Posted : 22/08/2011 11:55 am
http://www.jejamescycles.co.uk/kmc-speed-chain-item145967.html
Gold one from JE James
Posted : 22/08/2011 12:02 pm
Yes, you can.
ta, was clearly just picking things up wrong!
Posted : 22/08/2011 12:11 pm
tang , 10 speed?
Posted : 22/08/2011 12:23 pm
 tang
yes 10sp
Posted : 22/08/2011 12:46 pm
So far I've found both the SRAM & KMC 10 speed chains powerlocks really tough to separate.
I haven't bought the tool described earlier as yet so, in the meantime, I feed a length of earth wire (stripped from household twin & earth) around either side of the link & twist the ends together using pliers until the powerlock pops open.
I've also refitted both many times after cleaning.
Posted : 22/08/2011 1:35 pm
Not personally found the KMC ones any harder to do than any other reusable link.
Posted : 22/08/2011 1:42 pm
 Haze
I found the KMC a bitch to separate, bought the tool for a few quid to make life a lot easier.
(for a bit of balance)
Posted : 22/08/2011 2:06 pm
I don't find the KMC [or the preceding 9sp SRAMs] need anything more than a gentle squeeze and push
Posted : 22/08/2011 2:20 pm
