10 speed cassette w...
[Closed] 10 speed cassette with all separate rings...
Does it exist? Trying to find a 10 speed mountain bike cassette, something with a big ole' range like somewhere between 11-36, maybe 12-36 where all the cassette rings are separate, so not pinned or on a spider. Long story short, got an idea for a very small cassette on the hope singlespeed wheels that will take 7 sprockets...
So far the ones I've seen all seem to be be connected in one way or another. Back in my day they came separate..... (tailing off into an old-man rant)
Posted : 21/04/2018 12:13 pm
 JoB
no
Jeff Jones modifies cassettes to fit onto singlespeed hubs, if you had the machines and skills you could do something similar yourself
Posted : 21/04/2018 12:58 pm
More likely on a cheaper one. Pretty sure the last deore one I took apart was all separate. Heavy, though. They are rivetted so you need to remove the rivets by force (drill the end, hacksaw between the sprockets or hammer and pin punch).
Posted : 21/04/2018 1:15 pm
I've had 7 on a Hope SS hub using a XT cassette. I wouldn't like to drop any if the in-between sprockets, I think it may screw the shifting up.
Posted : 21/04/2018 1:43 pm
I've got a 10 speed hub that I used with an expander that got rid of the 15/17 for the one-up 16t, thought If i could get away with finding a separate 28 or 30t and a bit of play with a b-screw. It'd climb like crap but for a play bike should be fine. Saves me nicking (borrowing... ahem) the wheels from the mrs' bike
Posted : 21/04/2018 4:53 pm
 cp
Cheap deore are just pinned, drill the head off and boom, you have a cassette full of individual rings and plastic spacers.
Posted : 21/04/2018 6:18 pm
If it is any help,I bought a 9 speed Sunrace 11 - 36 cassette from Merlin a couple of weeks ago.All the cogs were separate & held together by one bolt.My guess is the 10 speed would be the same.
Posted : 21/04/2018 9:11 pm
<span class="skimlinks-unlinked">All</span> the cogs were separate & held together by one <span class="skimlinks-unlinked">bolt</span>
I mean that just doesn't sound safe! I'll see if anyone I know has a sunrace I can take a look at.
Posted : 21/04/2018 11:12 pm
I was going to suggest the Sunrace too. There's one bolt and a couple of pins. Personally, I don't like them as you can end up with a bit of play. I'm not totally convinced it causes any problems, it just "bothers" me.....
Posted : 21/04/2018 11:25 pm
This.
Done it several times before, nobody died to death... Yet.
Posted : 22/04/2018 9:36 am
Done it several times before, nobody died to death… Yet.
Have you got any still knocking about by any chance? 😉
Posted : 24/04/2018 11:22 am
I remember some of the shimano ones used to have bolts rather than rivets through, I'm guessing from the responses above these don't exist in 10s.
Posted : 24/04/2018 1:01 pm
Doesn't look that way. Sram 9sp looks to have got separate rings, but then it's the dodgeyness of using a 9-speed  28t ring with a 10sp cassette and just becomes all kind of hell
Posted : 24/04/2018 3:49 pm
Miche 10-speed road cassettes are single sprocket. You may need to swap spacers for MTB usage. They go pretty big too. I used a junior cassette for my nephew as there are gear restrictions for racing by age. About £25 on ebay and have seldom had a hard life.
Posted : 24/04/2018 4:17 pm
You may have just nailed it. There's a 12-29 that I reckon would do nicely on ebay at the minute if he'll take a bit of an offer on it. I think out of that I'll be able to fashion a reasonable 7 speed 10 speed cassette
Posted : 25/04/2018 11:02 am
Yes..... SRAM PG1020
I've got one here to donate to your cause if you want it FoC.
the biggest/2nd are together, but the rest are completely.
Posted : 25/04/2018 11:06 am
I have the set up you're taking about on my dirt jump bike - 10 speed SRAM cassette cut down onto a Hope SS freehub. I just bought a SRAM cassette from the bottom end of the range, put a big screwdriver behind the biggest cog and pop it apart. Then use the spacers to form a new cassette.
Posted : 25/04/2018 11:08 am
I’ve got one here to donate to your cause if you want it FoC.
That would be absolutely amazing man! Where abouts are you based? If you're not local I'm obviously happy to send you some money for the postage and what not!
Posted : 25/04/2018 12:00 pm
Where abouts are you based? If you’re not local I’m obviously happy to send you some money for the postage and what not!
Newbury way.
If an issue, ping me a mail, it's in profile.
Posted : 25/04/2018 12:03 pm
Marchisio sprockets
Posted : 25/04/2018 1:31 pm
