Backpacking bag for...
[Closed] Backpacking bag for a lefty
[#9952871]
im currently starting out bikepacking on my Salsa Vaya, currently running a kanga on the front but it’s not compatible with the lefty on my cannondale. If I decide to take the Habit on a longer more technical challenge I need a handlebar harness that with fit the lefty. Any ideas?
Posted : 21/04/2018 1:14 pm
I think the best solution would be to make/get made a small rack, either minimal to support the harness bag or a bit more detailed so you could just strap a dry bag straight on.
Two upper mounts on to bars and a single lower mount. Does the steerer tube have a hole at the lower end? You could fit an expanding plug and fix a mount to that.
Posted : 21/04/2018 1:35 pm
Ideally I’m after one that uses the head tube as a lower support point rather than two straps that go round the fork
Posted : 21/04/2018 2:30 pm
Have a chat with Beth at Wildcat
http://www.wildcatgear.co.uk/shop/
If they don't yet have a product they may have another solution
Posted : 21/04/2018 3:00 pm
Revelate and Alpamayo both do harnesses that go round the bars and head tube, not the fork legs.
Posted : 21/04/2018 3:11 pm
Ortlieb bar roll attaches straight to the bars and head tube ,I've got both a kanga and a ortlieb , I much prefer the ortlieb it just seems there's much less movement with it ,if you shop around you can get one for about £75 ,plus it's 100% waterproof even if you drop it in a river
Posted : 21/04/2018 3:25 pm
I  prefer a harness that the drybag can be removed from so the Ortlieb wouldn’t suit I’m afraid. I’ll give Andy at backcountry Scots a call as the site is showing the revelate one is out of stock
Posted : 21/04/2018 3:35 pm
On One Podsacs - ditch the three rather useless velcro straps, replace with two long wrap-arounds and a short stem/head tube attachment, and you have a perfectly competent harness and drybag for £15.
Posted : 21/04/2018 9:32 pm
The Blackburn one will work. A mate used it around the Cairngorms Loop with a Lefty and it was fine.
My Revelate harness would work fine
Posted : 21/04/2018 11:01 pm
My harness from Triglav would work, it doesn’t attach to the forks.
its a very similar design to the Revelate one.
This is the Revelate one:
https://backcountry.scot/product/revelate-designs-harness/
Posted : 22/04/2018 9:14 am
Just doing a bit of research on google images, found a guy in Poland, bikepack.eu, the double twist harness looks ideal. Anyone any reviews
Posted : 22/04/2018 11:37 am
I am in the same boat, have considered the Topeak Frontloader.
whatever you choose, won’t the myriad of cables be in the way?
Posted : 22/04/2018 4:03 pm
I only have two brake cables, a remote dropper cable and a single shifter cable do not really a myriad. Should work fine, I hope.
Posted : 22/04/2018 11:19 pm
