10-42 cassette 10 ...
[Closed] 10-42 cassette 10 speed vs 11 speed
I need to replace a worn out rear mech and shifter so thought I'd swap out the cranks as well and go for a 1x setup for simplicity. Am I likely to notice the one or two larger jumps on a 10spd cassette versus an 11spd cassette with the same range?
Posted : 18/10/2016 7:25 pm
Can you buy an 11 speed with same range?
Actual question not trying to be clever
Posted : 18/10/2016 7:29 pm
Sorry, typo in the original post - I meant 11-42 not 10-42.
Sunrace do a 10spd 11-42t (do a quick search on your favourite Irish bike parts website)
and SRAM NX/Shimano SLX/XT are 11spd 11-42 as well.
Posted : 18/10/2016 7:39 pm
TBH jumps are all about you, some people care about it, some don't. I can't stand a narrow ratio cassette, I just end up double shifting all of the time, so fair to say, I wouldn't care about the differences here.
Posted : 18/10/2016 7:46 pm
It's all about range for me. I'm about the only one running 10 speed in my group these days, but it's fine. 10spd is still significantly cheaper too.
Posted : 18/10/2016 8:03 pm
Don't mind me, I'm just going to pull up a chair and see if anyone has anything interesting to say about them there sunrace cassettes...
Carry on.
Posted : 18/10/2016 8:46 pm
I've had the black one with the al big sprocket on since march and I can confirm that broadly, it is a cassette. Only real point of note is that until recently it had a bit of a problem with dropping the chain on back pedalling in the lowest two, but it seems to have settled down. Which is odd, because i would consider it to be starting to wear out rather than wear in based on how long a normal xt lasts me.
That's with a rad cage.
Posted : 18/10/2016 9:34 pm
sunrace mx 11-42 10 speed here done hundreds of km, still happy
Im in no rush to go 11 speed
Posted : 18/10/2016 9:49 pm
11 speed is one better that 10 so should win every time.
Posted : 18/10/2016 9:53 pm
