[Closed] 1 x 9
[#5057140]
Does anyone run 1x9 or does it not offer enough in the way of range?
I'm contemplating it as I can't afford to go 10 speed at the back and can't be arsed with a twin chain device at the front.
Posted : 11/04/2013 3:38 pm
I have 2 bikes running 1x9 - one with a 36 front ring (which can be a struggle, tbh) and one with 34. Both have a 32 max rear cassette.
You can get a 34 max 9 speed cassette so unless you need a really low gear for climbing you'd be fine.
Posted : 11/04/2013 3:42 pm
I do, 32 x 11-32 gets me up everything on the South Downs. No really long climbs but plenty of reasonably steep bits. If I went a 10 speed I'd probably go for a 34 x 11-36 to give a little extra at either end but what I've got is good enough until it's worn out.
Posted : 11/04/2013 3:44 pm
I run 1*10 on one bike, depends how strong you are / how hilly it is where you live. Plenty run 1*10 with a 34 or 36 front, and a 36t rear, so a 11:34 cassette with a 32 or 34 front will be broadly the same for the ups and give away a little on your biggest gear.
Also depends whether you are talking about a 26er or a 29er. If the latter you can knock a couple off the front to accounts for the bigger wheels. Personally - I'm on a 29er with 32 front and 11:36 rear.
Posted : 11/04/2013 3:45 pm
Cool, I reckon I might have a go at this next week when I get paid, I run a 26" so might be a bit more of a struggle up the hills but I could probably do with trying a bit harder up them any way.
Posted : 11/04/2013 3:49 pm
i do on my HT. i run a 32t up front so i can do most climbs locally. i'd struggle with long steep climbs, but i would with 10 speed also. top end i only spin out on long down hill fire roads, the boring stuff. i don't thing one extra gear will make any real difference.
works for me and getting me fitter 😉
i do have 2*10 on my full suss tho for all day stuff
Posted : 11/04/2013 3:50 pm
Just ditched my front and got 39/11-32 which is a bit of a struggle on some of the hills but generally feels great. Thinking of bodging a 11-36 on the back and maybe losing a couple of teeth on the front.
Posted : 11/04/2013 5:15 pm
My hardtail is 1 x 9. 36t up front with 11-32 cassette. Climbs like a goat! Although got a bit flabby over the winter so I can often hear the 34t ring calling me from its hiding place in the shed.
Posted : 11/04/2013 5:19 pm
I run my full sus 1x9, 36 at the front, I'm upgrading to a 11-34 at the back as the 11-32 does run out a bit on steep climbs (though they're still possible). So I'd recommend it, saves you weight and money for little loss in my opinion.
Posted : 11/04/2013 5:25 pm
Yup, 32t front ring and 11-32 on the back lets me winch up even super steep technical sections without feeling like I'm pushing too big a gear. You only need to go 1x10 if you're fashion conscious or have the legs of a small girl. And if you haven't got the legs then you'll get them quickly! 🙂
Posted : 11/04/2013 8:38 pm
Hmmmm says the person who just got a 38tooth ring for his 1x9 29er project. Good job im in the fens then 😆
Posted : 11/04/2013 10:59 pm
But 1x10 can have a clutched mech
Posted : 12/04/2013 2:29 am
40, 11-32 here. Fine for trail centre's n local XC
Posted : 12/04/2013 10:05 am
The clutch mech is what I really want but don't have the wonga to splash on new cassette, mech, chain shifter etc so will probably just drop a cog at the front and get a cheapish chain device so technically won't save any weight or money (maybe a little weight but I could probably lose more a lot quicker in the bathroom before a ride).
so....
what chainguide and ring for the front then. I was looking at just getting a cheap set up from superstar, probably don't want to spend more than £50-£60.
Posted : 12/04/2013 1:49 pm
Can't remember this topic ever being covered before?
Posted : 12/04/2013 1:53 pm
My C456 runs 34T/11-34 gets me round my local loops and was ok round llandegla (I am at the unfit end of our riding group).
Cheap Superstar top guide has worked fine.
Posted : 12/04/2013 3:20 pm
My Soda's 1x9, though with a clutch mech (X9 shifter + mod + SLX). It's not quite as good as my 1x10, the 36T cassette isn't a massive difference but it does seem to be the slight difference between "good enough" and "slightly hard work". Or to put it a different way, there were a few times last week in Wales when I wished for a lower gear on the 1x10, where on the 1x9 I'd have been in a higher gear.
Posted : 12/04/2013 3:42 pm
I have soda too on a 1x9 set up. . Works really well. . For xc stuff . . Not yet tested Wales etc but feel it will be fine. . Only now and again do I think I need a few extra gears, very steep stuff and getting quick speed on descents. . It is a perfect set up for xc racing with the leg strength! Standard xt cassette wi E13 ring/ chain guide ZTR shifter.
Posted : 12/04/2013 5:57 pm
I run 1x9, 36t chainring and 11-34 cassette. I find the range is enough, you just have to learn to power up things opposed to sitting and spinning. I've never found a climb at a trail centre I couldn't make but sometimes I have to get off and push in the Peaks. I'm considering swapping for a 34t ring.
I'm running ancient X7 with SRAM cassette and an old E13 LG1 w. taco bash guard.
Posted : 12/04/2013 6:03 pm
tommy - you don't really need a dedicated chainring for 1x9. I just removed the inner and outer rings from my Shimano cranks and made do with the 32T. Add a superstar xcr bb mount chain guide for £16 and it was fine. There was a little bit of rub running 32 front to 11t sprocket but bearable. I ran 32 x 32-11 on my C456. Now I'm running 34 x 36-11 (10 spd) on the full suss, just to get a marginally wider gear range (top and bottom)
If you really do want a dedicated front ring, then there are FSA ones on ebay for less than £20 depending on size. Which is generally cheaper than e-thirteen, Hope etc.
Posted : 12/04/2013 7:48 pm
 Keva
36/11-32 here. Perfect for local trails and visits to S.Wales trail centres. Other places I ride demand a smaller front chain ring so I take a different bike 😉
Posted : 12/04/2013 7:55 pm
You can get a stainless chainring from on-one cheap, which will last a lonnnnnnng time but are not reversible like some.
Posted : 12/04/2013 8:14 pm
34t strongly recommended here
