1 ring on the front
[Closed] 1 ring on the front
[#5820190]
Now this may be a silly question but I have always run 2 or 3 rings on the front of all the bikes I have owned. As it's a really cacky out there at the mo, I have un-mothballed my old hardtail to use in the muddy conditions. I want to run a single ring at the front. Is it as simple as remove the upper and lower ring, take off the shifter and derailleur and job done? Will my chain bounce off , do I need a retainer etc etc? Thoughts would be appreciated.
Posted : 03/01/2014 1:40 pm
only really need 2 things,
-shorted chainring bolts/or washers (to take care of only having 1 ring)
-chain device on top, either leave your front mech on or get something like this from superstar: (£20)
That will stop your chain bouncing off. There are lots of other versions also.
Posted : 03/01/2014 1:43 pm
Standard ramped rings with no clutch mech then it will probably go missing.
Single ring (non ramped) may help
Clutch mech and thick thin ring seems to be popular.
A single ring chain device would work very well though
If you're using a none-clutch mech, I'd stick a chain device on myself. They don't have to cost a fortune. I run a Superstar Plasma on my BFe and it does a pretty good job (especially at less than half the price of an E13).
Posted : 03/01/2014 1:54 pm
n-gear jump stop and BBG Bash - a set up which is pretty cheap, light, simple and quiet. Splashed out on an e-13 g-ring though.
Posted : 03/01/2014 2:19 pm
Mate of mine has a triple up front on his hardtail. he's replaced the outer ring with a bashguard, and has got a seat tube mounted upper chain device with the chain on the middle ring. I think he's running a 9 speed out back. This is fine for the majority of his riding he does on that bike and seems to work fine in terms of not dropping chains.
Posted : 03/01/2014 2:22 pm
Just leave it as it is. You never seem to have any problems at the front anyway.
EDIT: Or see if they can knock up a couple of bash rings at work - one for the outer and one for the granny.
Posted : 03/01/2014 2:40 pm
This is the cheapest and sounds the most suitable for a bike you just un-mothballed.
Posted : 03/01/2014 2:48 pm
Hi
I use a clutch type rear mech and a bashwich up front, bashwich might be enough on it's own though.
Posted : 03/01/2014 2:50 pm
Thick/thin chainring is a much better option than a top-only chainguide ime... Top guide even with a clutch mech was tolerable at best but magic chainring even without a clutch mech is better (not to mention much easier to sort out if the chain does come off...)
But is your existing kit 9 or 10 speed? Not so sure about chainring voodoo with a 9-speed chain...
Posted : 03/01/2014 3:09 pm
Yep, you got it.
Shorten the chain.
Wait and see if you loose your chain after a few rides. If you do, fit chain guide.
Done.
Posted : 03/01/2014 3:14 pm
