08 Orange Patriot- ...
[Closed] 08 Orange Patriot- explain stroke. Would this work?
 hora
Currently running a 215x15 shock. Ive seen a 200x57 CTD shock that would also fit?
Look at the attached image. I'd fit the 200x57 one space back thus equalling the length/current angle approx? I dont mind the slight drop in travel. Is this thinking right? How wrong am I?
www.flickr.com/#/photos/30625376@N06/13794810683/
Posted : 12/04/2014 9:42 am
There was a larger shock shuttle for short air shocks, not sure if you'd find one these days
Posted : 12/04/2014 9:43 am
privacy on the pics again?
Assume you mean 215x51?
Posted : 12/04/2014 9:49 am
 hora
Found this. It says you only need a short shock shuttle for the 190?
singletrackworld.com/forum/topic/patriot-66-shock-info
Mike try this
www.flickr.com/#/photos/30625376@N06/13794810683/sizes/l/
Posted : 12/04/2014 9:51 am
Pretty sure you can run 200x57 on the long shuttle, but you need the short shuttle to run 190x50.
Posted : 12/04/2014 10:03 am
 hora
The length would equal out then, only the travel available would drop? Simply move the shuttle back to the final hole to action? I do want similar geo.
Posted : 12/04/2014 10:06 am
200 /57 on the normal shuttle is fine, ran my 08 patriot like that for years with a lyrik. Gives 160mm travel near enough. I ran mine with 215mm, 200mm and 190mm shocks, and preferred the 200 for most things.
Posted : 12/04/2014 10:39 am
I assume he means 215x65...
Posted : 12/04/2014 11:02 am
 hora
Its adjustable ๐Ÿ˜‰
Posted : 12/04/2014 1:56 pm
Why don't you try that shock of mine to see how it affects things
Posted : 12/04/2014 2:33 pm
 hora
The one in 4 bits? Could do but it Loco would need to fix.
Posted : 12/04/2014 3:40 pm
 DeeW
Pretty sure it was a 200x57 I fitted to mine. So long ago now I forgot the original and new shock dimensions though.
anyway a slightly shorter eye to eye shock with shorter stroke will allow you to lower the bb and slacken the head angle a treat. You will lose a tiny bit of travel if that bothers you. I moved the shock shuttle forward as far as I could without the rear tyre hitting the seat tube at full travel to lower the bb. IMO makes a far better trail bike set up like this.
Posted : 12/04/2014 7:13 pm
