Air springs have come a long way, my old z4’s were horrible comparedeven to my manitou minutes (the old original ones) which I still think are horrible.
I had some ’02 Z1 MCR’s which were great forks, with a simple to understand rebound adjustment and coil springs. Compared to the Menjas they were replaced with
Zochi
linear
controlled damping
under sprung, and not progressive (sorted with stiffer springs and more oil, but at a cost).
Compression damping was there, but I’d prefer more and/or adjustments, odly it had a rebound damper in each leg, makes it super plush as its damping a lot of oil, but surely it would cost no more to have made one a compression damper?
menja
lighter (a lot, ~2lb, maybe more)
stiffer (a lot, this is probably the most noticable thing)
‘wallowy mid stroke’ MBR speak for a not particulalry great air spring design.
Rebound seems stuck between not enough low speed to prevent top out and too much high speed to allow the fork to extend quickly, so one click either side of the ‘correct’ setting either results in it packing down or topping out, and the ‘correct’ setting still feels comprimised.
Badly needs some propper compression damping, and less of a spike.
Swings and roundabouts. One day I’d love to bucher some z1 internals into the menja chassis.
RS seem a good comprimise between being plush (but not as much as zocchis which completely flatten the ground for you) and firm (like fox). Rose tinted glasses asside the RS forks are probably better than the Z2’s.
