Your favourite engi...
[Closed] Your favourite engineering related word - what is it?
[#1650623]
Well? 😉
Posted : 27/05/2010 10:43 pm
Bastard file
the tech teachers at our school used to call you a file if you annoyed them
Posted : 27/05/2010 10:44 pm
more materials than engineering but I always liked 'frangible'
Flange
**** you Munro...beat my ass!
Posted : 27/05/2010 10:46 pm
Cannae really beat gusset though can you.
Gusset
Posted : 27/05/2010 10:47 pm
But I was very entertained when I heard people talking about male and female parts!! How naive was I?!?!
Fabrication
Posted : 27/05/2010 10:48 pm
 ton
swarf
Posted : 27/05/2010 10:49 pm
****ed
Flange for sure!
LART.
E_L - good technical term that one.
Think if comes from the same text book as the one that gives us "big **** off" as a unit of measure. 😀
Posted : 27/05/2010 10:51 pm
 R979
Erection
I like 'trunion'.
and 'learning stick'.
Posted : 27/05/2010 10:52 pm
pinion
Posted : 27/05/2010 10:56 pm
mines has to be a unit of measurement we use at work when estimating something from a distance ...and that is "oooh it looks about an alexeis finger"
based on that one day a chap at work called alexei when asked to measure something stuck his finger up to the componant and said to the engineer its about the same as my finger .....
Posted : 27/05/2010 10:57 pm
Fulcrum.
Posted : 27/05/2010 10:59 pm
Spigot.
Posted : 27/05/2010 11:00 pm
foo foo valve - name given to any component that you don't know the name of
Posted : 27/05/2010 11:01 pm
got to go with flange
Posted : 27/05/2010 11:02 pm
what about nipples and cleats?
Posted : 27/05/2010 11:03 pm
or "cock hair"...a very small measurement..ie...."just take half a cock hair off the outside diameter."...typical measrement term used in the tool room during my apprenticeship.
Posted : 27/05/2010 11:04 pm
Bollocksed, or bolloxed.
A bit bolloxed.
Bolloxed.
Proper bolloxed.
Completely bolloxed.
Totally ****ing bolloxed.
Posted : 27/05/2010 11:06 pm
Lube.
Posted : 27/05/2010 11:07 pm
interference fit
Posted : 27/05/2010 11:08 pm
 WTF
rockhopper70 - Member
The metric equivelant is a pubic millimetre.
Posted : 27/05/2010 11:11 pm
Percussive maintenance.
(ie, if it doesn't work, hit it till it does.)
 WTF
Reamed
Flange.
Posted : 27/05/2010 11:12 pm
I met a potential client the other day who have seamless and flash-butt-welded ring manufacturing capabilities.
k'snurk.
Posted : 27/05/2010 11:13 pm
So how many cock hairs are in a gnat's bollock then ?
Posted : 27/05/2010 11:14 pm
 ton
carborundum
Posted : 27/05/2010 11:15 pm
Very funny 😀
Posted : 27/05/2010 11:17 pm
Interference Fit is what a designer calls two parts that he has designed to fit together that don't! IE Why wont this 20mm shaft not fit in the 20mm hole. Cos they are both the same size you Tw*t. I hope you have some Vaseline so the Doctor at A&E can remove the shaft from your Ar..
Designer = A failed engineer that can't be trusted on the shop floor!
haha interferance fit - thats another name for "get your van and take that to the machine shop for boaring" round here
Posted : 27/05/2010 11:18 pm
"tool; fine adjustment"
Hammer (army style).
Posted : 27/05/2010 11:19 pm
Ft
Posted : 27/05/2010 11:22 pm
friable - is that an engineering term ?
Gudgeon pin has always been one of my favourites.
Or one we use on apprentices... Think you better change the 'dip-van oscillator valve'
Posted : 27/05/2010 11:41 pm
My mate, on the phone one day, trying to explain the ovalisation of a hole to a sub-con machinist..."Its ovulating".
Posted : 27/05/2010 11:53 pm
Pupped Flange Assembly
Posted : 28/05/2010 12:09 am
Another one for flange here.
Posted : 28/05/2010 12:18 am
Clacker valve, makes me smile!
Posted : 28/05/2010 12:20 am
