Yeti 575 - why did ...
[Closed] Yeti 575 - why did it climb so well?
[#584933]
GF is looking for new bike, and has tested quite a few recently. Was really surprised by how well 575 climbed, and wondered if anyone knew why? Ta!
Posted : 27/05/2009 9:03 pm
I've no idea,but it is a great climbing bike.
Posted : 27/05/2009 9:19 pm
But not so great descending bike
Posted : 27/05/2009 9:21 pm
Geometry. Quite simple.
Posted : 27/05/2009 9:31 pm
nasher - rubbish, goes down well fast. What forks you running?
Posted : 27/05/2009 10:14 pm
theres another thread on this somewhere, could be something to do with the suspension extending under power?
Posted : 27/05/2009 10:16 pm
Mine is crap up hill... think it's an engine problem though.
Goes well under gravity assistance though 😉
Posted : 27/05/2009 10:36 pm
I bet JVC is your girlfriend.
What does it matter "why" anyway? It's just bloody great innit.
(apart from the [b]flex[/b] of course. [b]YAWN[/b] )
Posted : 28/05/2009 9:35 am
Nasher: are you unwell? The 575 is awesome downhill, it rides over everything.
Climbing is good and the latest incarnation of the 575 climbes better than the '06 shape.
575 awesome!!! Go Yeti!!! eeer I'm getting carried away somebody stop m...
Posted : 28/05/2009 9:43 am
 JVC
SweetJumps, I felt like the 575 was a bit 'over the front' on big steps and that the Lapierre floated down them with ease, inspiring confidence. Do you not get that feeling with the Yeti?
Posted : 28/05/2009 10:08 am
Slacker angles on the Lapierre probably. Also explains why the Yeti climbs better. If I was considering changing my Yeti I'd look at Lappierres, but it's not going anywhere yet! 3 years on I'm still loving it.
Posted : 28/05/2009 10:17 am
"over the front" on steps
well, the Lapierre Spicy has longer forks and slacker steering, plus a laid back seat-post, so the front will sit higher and your weight will be further back, so yes, should ride steps and very steep bits easier
stem length will have an effect too - if you had a longer stem on the Yeti it will pitch you further forward
Yeti with 160mm forks and short stem would be closer to the Spicy I think - I guess yours had 140mm forks on it? It is designed to take up to 160mm which slackens the angles and makes for a more "All Mountain" set up, but would probably feel a bit lazier up hill. I considered this for mine but decided 140mm was more appropriate about 95% of the time
the converse will be true up hill to an extent. The slightly more relaxed Spicy will probably feel a bit harder work - which seems to be what you experienced.
I think a consideration often ignored is the "along" mountain bit. Everyone talks about climbing and descending, but if a bike is harder work along the flattish bits, it will knacker you out. I think the Singletrack review suggested you had to work the Spicy pretty hard on the traverses
'orses for courses
oh and I am 15 1/2 stone of burly rugby bloke. The old 575 was maybe a bit flexy, haven't noticed any flex on the new one. I am no downhill God, but have a Motorbike Enduro background so don't mess about - passed loads downhill at the Dyfi
so in conclusion
- 575 and Zesty are a better comparison
- Spicy probably closer to the new Yeti 7 (burlier 7 inch version of 575)
- be sure what you are experiencing isn't due to something like stem length / riding position / fork length, rather than a difference in the frame
if that helps.............
Posted : 28/05/2009 10:38 am
